my first boat
  • WeeZ65
    • Jun 2020
    • 7
    my first boat
    Hello everyone , i've been into rcing for a while , wanted to try something new so bought a Proboat Formula from a friend for cheap , it was collecting dust in the box for a while . i was scooting around the pond and musta hit something and broke the flex shaft where it couples to the prop shaft , they don't make that part anymore and i can't find one . is there anything i can do ?
  • Ch.Lucas
    • Nov 2014
    • 66
    Hi,
    can you make a photo of the outbord and where the flexcable is broken and how long is the flexcable and what type of cuppling it has.
    Happy Amps Christian
    • WeeZ65
      • Jun 2020
      • 7
      theres like 3 different numbers for this part so i'm not sure what the length should be oh and the grub screw is striped
      • Ch.Lucas
        • Nov 2014
        • 66
        Hi,
        i will contact a friend i think he knows the lengh . Do you the dia of the cable ? maybe you can buy it here at OSE and than you can insert it and glue it with Loctite or you can softsolder it or we find a way . Let see.
        • WeeZ65
          • Jun 2020
          • 7
          the only number i'm coming up with is .150 and it's either 195 long or 186.5
          • Ch.Lucas
            • Nov 2014
            • 66
            Do you see this cable offert from OSE , https://www.offshoreelectrics.com/pr...ex+Cable+Parts , there are 0,150 the lengh you have to cut , best with a dremel and cutting disc but a grinder will do the same job . Look around , is there no maschine shop where you can aske for help ?
            • WeeZ65
              • Jun 2020
              • 7
              no i can do it myself , thanks for the help Christian
