Stuffing tube
  • Jonathan DeMaria
    • Jun 2020
    • 110
    Stuffing tube
    Why does my liner in the stuffing tube move up towards the motor in my blackjack 29" v3 & how do i fix it??
  • fweasel
    master of some
    • Jul 2016
    • 4285
    Could be a mis-alignment between the motor mount and stuffing tube, or a cheap stock collet with a lot of runout. If those check out, you can pull the liner forwards, clean it with some alcohol, put a few wraps of teflon tape around the end, then slide it back in. The teflon tape creates an interference fit, so you may need more or less to get the desired result.
    • ray schrauwen
      • 9471
      Nice tip. ^^^^
      • properchopper
        • 6968
        The twisted flex has a lay for CCW props that climb upward towards the motor collet which acts on the teflon and pulls it upward.
        • Jonathan DeMaria
          • Jun 2020
          • 110
          What does a lot of run out mean? New to fe boats
          • fweasel
            master of some
            • Jul 2016
            • 4285
            it means it's either poorly machined out of center or fits poorly on the motor shaft. Both visible as a wobble when spinning.
