Aquacraft Revolt 30?
  • jerry123
    • Feb 2014
    • 75
    Got a chance to pick up a brand new in the box never opened aquacraft Revolt 30. Has anybody used this in P limited mono and if so is it any good. I don't care if I win or place just want to have fun and finish the race.
  • Speed3
    • Mar 2017
    • 371
    The revolt is a very nice boat. I never ran one in p limited mono. But I can tell you it corners like its a rails.
    I would suggest that you give the trim some negative trim. 2 turns negative on each tab. It can also run through chops at high speeds. That's with that tabs set right.
    I personally have my tabs on mine around 4 or 4.5 turns negative cannot remember exactly.
    I set my tabs with that much negative because I run a lot of power in mine. Example leopard 4092. I ran on up to 6s with a 1730kv leopard 4092 with a x642. And 5s with an m545.
    I suggested 2 turns negative for you because p limited power is nowhere near the power I run and the boat will loose a little speed when it runs to wet.
    You have a nice boat for certain.
    • jerry123
      • Feb 2014
      • 75
      Thank you for getting back to me so soon I appreciate the info.
      • jerry123
        • Feb 2014
        • 75
        Did you upgrade the flex shaft as I see the stock one doesn't hold up well. Also did you upgrade the rudder for dual Cooling.
        • Revolt Flash
          • Aug 2015
          • 437
          I run a .187 cable without the liner in mine. Leopard 4074 2000kv 180 ESC on 6s with 645 prop. It looks like a waterbug running in the water.
          I also run negative trim on the trim tabs.
          • eric113
            • Sep 2011
            • 323
            I was given revolt from a club member. I also plan on running it as P limited mono.
            Already swapped stock connectors to 5.5 on the motor and battery’s.
            I need to get new linkage boot, new flex cable.
            • jerry123
              • Feb 2014
              • 75
              Are you planning on running 2 4S in parallel to make sure you get enough run time to finish a race?
              • eric113
                • Sep 2011
                • 323
                I was planning on 2 2s in series.
                Really all you need 5-6000mah to finish a race that includes a mill lap.
                • Capt'n Crash
                  • Mar 2015
                  • 166
                  The Revolt 30 is an excellent boat. I liked it so much I got three of them but none of them passed the bathtub test.
                  A little bit of silicone sealant behind the bolt plates solved the problem. Also 2x 2s 5000 mAh bateries in series will give you a 4 minute run without depleting the batteries to a dangerous level.
                  • jerry123
                    • Feb 2014
                    • 75
                    Where did you get your 187 cable from. Did you have to cut it to fit. And how did you keep water from getting in the hull?.
                    • eric113
                      • Sep 2011
                      • 323
                      https://www.offshoreelectrics.com/pr...ose-cable-187L
                      If you have a dremel with cut off wheel you can cut it down down to size.
                      You will need to pull the Teflon tube out of the stuffing tube.
                      • Speed3
                        • Mar 2017
                        • 371
                        I ran the upgraded shalf that offshore electrics sells.
                        • Revolt Flash
                          • Aug 2015
                          • 437
                          I bought a longer cable off this site. I cut it to fit and use grease to lube it every other run. The grease acts like a seal and helps keep the water out.
                          • jerry123
                            • Feb 2014
                            • 75
                            Did you use the same coupler that came with the boat or did you have to use a different one for the .187 cable? If so could you point out which one you used.
                            • jerry123
                              • Feb 2014
                              • 75
                              Did you use the same coupler that came with the aquacraft or did you have to buy a new one to fit the .187 cable? If you had to buy a new one could you point out which one?
                              Sorry for being such a pain in the butt.
