Tunnel Hull & Outboard
  • DLS II
    • Dec 2008
    • 2
    Hi, I have a Thunder Tiger Falcon 3.5 and EP1 outboard. The EP1 has been remotored with a Feigao 10L. I have a couple of questions. I usually play with rc cars, boats are relatively new to me. 1. In what position should the EP1 be mounted? I know it mounts in the same area as the glow outboard, but I'm not sure how far up or down the prop or surface ride plate should be relative to the "bottom"-Keel? I planned on using 4s or 4s2p A123 Li-Ion (13.2 volts) for power-speed control suggestions? Thanks, Don
  • SJFE
    • 4735
    Don mount it as ou would the nitro setup. Unless the lower on the nitro setup is drasticky different. 4s-2p will work but the week link is the geraing in the ep1. Be sure and pick up some extra sets here @ ose.
    • DLS II
      • Dec 2008
      • 2
      OK, that means I'll need a custom mount to drop it about 7/16". And I'll get some extra gears. Thanks, Don
