Motor???
  • Damien
    • Dec 2019
    • 19
    Motor???
    Need help with motor choice got a 41? cat running 6s2p 250a esc with a x447 what size motor will best suit set up?
  • TRUCKPULL
    • 2969
    41? cat
    Sponson tips to transom, with out hardwear.
    Larry
    • Damien
      • Dec 2019
      • 19
      41 inch fightercat fantasm hull
        What does the OP want to do with the cat? Oval racing, top speed runs, general bashing? What are his speed expectations? What is the capacity of his packs? Why does he want to be limited to one rather small prop?
        • Damien
          • Dec 2019
          • 19
          General bashing but would like it fast without heat problems running two 5000mah 6s in parallel 60c packs just want to now best prop for boat single motor
          • Speed3
            • Mar 2017
            • 371
            You can should look into a leopard 4092 1480kv.
            • Damien
              • Dec 2019
              • 19
              Thanks what tp motor would you recommend looking at one of them and kv
              • Speed3
                • Mar 2017
                • 371
                I have ran a tp 4060 1950kv, and a leopard 4092 2080kv. The both of them are 4092 cans, 60mm rotor length. The tp has significantly stronger magnets than the leopard. The 2 motors would have had the same kV but because of the strength of the tp magnets the kV is 1950 to 2080.
                But the things is my leopard 2080 is at least 5mph faster than my tp. The leopard have a higher kV and holds the rpm better underload. And the leopard also runs cooler. Same hull, same prop, same ESC, same timing and same battery.
                So for this reason I recommended leopard over tp.
                But if you really want a tp the 4060 4y 1350kv or the 4070 3y 1520kv would be my recommendations.
                • Damien
                  • Dec 2019
                  • 19
                  Thanks for info want about tp4050 recommendations in kv???
                  • Speed3
                    • Mar 2017
                    • 371
                    For the tp 4050. I would suggest the 4050 5y 1330kv. My suggestion are for a good balance of reliability, speed and runtime. Using the 447 prop.
                    • Damien
                      • Dec 2019
                      • 19
                      Thanks for the info much appreciated
