MHz c5000 Mystic 1140
  • Oddi
    • Nov 2019
    • 3
    I have The original MHz drive but my flex is bend. Can i use another flex for this drive? Or is it important that the stiff part is the same length. Just started my build and bought some used drives.
  • fweasel
    master of some
    • Jul 2016
    • 4291
    Depending on which drives you have, the replacement prop shafts would need to be long enough to be supported by both front and rear bearings, and short enough that they did not extend out past the drive. Obviously, they would also need to be the same diameter as the bearings inner diameter measurement.
    Vac-U-Tug Jr (13mph)
    • Oddi
      • Nov 2019
      • 3
      Ok thanks :) then I have som research to do :) the original shafts is kinda expensive to get in to Norway.
      • fweasel
        master of some
        • Jul 2016
        • 4291
        MHZ ships all over the world. I just placed an order last week that made it to the US in 2 days!
        • Oddi
          • Nov 2019
          • 3
          I will order it from MHz. I have been looking in to it. And the prop shaft end and flex is 3/16 and the shaft supported by bearings is 1/4 so I think the best option is to order original.
          Mounting the drives tomorrow:) my winter project:)
