I have a outrunner which can run on 2s-4s and was monking around with 2s . Now after running with 2s, the motor would stop after 5 seconds. I tried others escs and got the same result . I hooked up 3s and all was fine and all the escs were fine. Many years ago I had a ADS which ran poorly on 2s and went to 3s and all was fine. Who knows! ? tho, do outrunners run best on 22-30 timing?
Boat keeps shutting down LVC?
Norwest.
Did you change the cell count setting in the ESC to 2s?
If not, the ESC would expect to be seeing a 3s voltage , but is only seeing 2s voltage & would be shutting down on low voltage under load.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Assuming that the packs are wired together with their remaining wires, the OP has 4S. The factory default timing on the 120a ESC is 7.5*, although I run that motor (in different boats) at 10*-15* without issues. As with any Y motor, the required timing depends on the amp draw.
.....ERROR 403 - This is not the page you are looking for
so the red esc wire goes to red wire on pack 1 and the black esc wire goes to black wire on pack 2, you have then joined the remaining 2 x plus and minus wires on packs together to form series. of 4s total. ? thats good. now set the esc to read a 4s battery.Comment
.....Vac-U-Tug Jr (13mph)Comment
TFL Zonda (124mph), Miss Geico Zelos 36 (108mph), Veles 29 (91mph), Zelos Twin 36 (90mph), Miss Geico 29v3 (83.5mph), Sonicwake 36 V2 (83mph), Blackjack 42 (81mph), TFL Pursuit (79mph), UL-19 (75mph), Sonicwake 36 (73mph), Motley Crew (47.5mph), AquaCraft Rescue 17Comment
just had my 180 esc shut down after a 5 secound motor boost as i am setting up a new 6s cat. sure enough theres nothing wrong with the esc or anything else , just me. i have the esc programmed to run on 6s and i only plugged in 1 x 3s pack , this definetly shows that if you set your esc battery power to a certain voltage and that voltage isn,t met the esc will shut down . good test even though i didn,t mean for this.Comment
I turned off the lvc to no protection. The boat still died after about 15 seconds and then would start back up again and then died again. My Flex cable is aligned perfect with the motor I have a 3 mm Gap between the strut and the drive dog. Do you think the motor could be causing the problem? I did a range check with the radio and it seems fine.Comment
The other esc related thing could be thermal protection kicking in. Agreed, try other props.
I’m having trouble imagining how it would be solely the motor... most likely motor-esc interaction"Look good doin' it"
See the fleetComment
