Need trim tab suggestions for 31'' monohull .
  • Andris Golts
    • Jan 2011
    • 504
    Hi all i have desinged a new 4s-6s 31'' long x9.5'' beam mono with a 24 degree dead rise . Should i be considering a split trim tab system ? What size tabs would be required for this size of hull ? Any specific system that i can buy from Offshore ? Regards Andris Golts.
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7128
    Are you sure you need trim tabs?
    "Look good doin' it"
    See the fleet
    • Speed3
      • Mar 2017
      • 371
      The revolt tabs worked well, not sure if you will find tabs like that for sale.
      But you need tabs that can be adjusted.
      To get a boat that size to its max potential you would need tabs.
      When I had first ran a m545 on a revolt it used to blow off the water with the stock power plant.
      With the right amount of negatives on the tabs. I was able to go a lot faster and used much more power in the revolt.
      The most power I ever ran in the revolt was a tp4060 1950kv on 5s with the m545 and the boat was planted.
      My problem became that the coupler could not hold to the shalf no matter how tight I set the collet.
      It was just too much torque on the .150 upgrade shalf. But the boat was planted.
      • MarkF
        dinogylipos.com
        • Mar 2008
        • 979
        Don't waste your money on split tabs. Tabs like these will work great. https://www.offshoreelectrics.com/pr...d=ros-spdt-100
