Help Me Choose a motor and prop
  • jacob9783
    • Jun 2019
    • 6
    Hello, i have a Proboat BlackJack 24.(catamaran Im ready to do some upgrades. not sure on what motor size and prop would be best. I want to get into the 40MPH club. (or higher)
    I bought a OSE Raider 150amp ESC and a 4S 75C 6500mAh
    Im looking at getting a leopard 3660 series or an X2 leopard 3660 but not sure what Kv to get?
    Leopard 3660
    2050Kv 2.5Y
    2550Kv 2Y
    Leopard X2 3660
    2380kv 4D
    3180kv 3D
    not stuck on getting a leopard motor, if you can help in selecting the right KV and prop size. im still new in the hobby. thanks for all your help.
  • Speed3
    • Mar 2017
    • 371
    I would go for the 2050kv 3660 and an octura x440.
    • rol243
      • Apr 2017
      • 1038
      can you buy T.P. Motors where you are ? better than the Leopards.
      • jacob9783
        • Jun 2019
        • 6
        yes, I can buy TP motors. well, what ever is on offshore electrics. Im located in California
        • rol243
          • Apr 2017
          • 1038
          The T.P. motors are a better motor than the Leopards.
          • NativePaul
            Greased Weasel
            • 2761
            That is a lot of weight for a 24" boat, I'd have gone for a 2860 motor of around 3400KV, on 3s 5000mAh, with a 1.4 pitch 36mm prop, and 120A ESC. it would still get you over 40mph, along with 5 minute runtimes, and likely much better handling.
            • jacob9783
              • Jun 2019
              • 6
              mmm... im currently running a 3650 2750kv with a grimracer 40x53 prop on 3s. am i doing something wrong?
              • jacob9783
                • Jun 2019
                • 6
                • Speed3
                  • Mar 2017
                  • 371
                  In my experience, the leopards are faster than the tp.
                  I cannot understand it, the tp have stronger magnets, looks to be a far better built motor than the leopard.
                  And the leopard runs cooler, and holds the rpm better underload than the tp.
                  The only issue I see with the leopard is they will kill bearing fast at real high rpm. Over 35000 plus rpm.
                  • jacob9783
                    • Jun 2019
                    • 6
                    so, what KV and prop would you choose?
                    I want to go 40 mph-ish
                    im going to run 4S
                    • Speed3
                      • Mar 2017
                      • 371
                      2050kv and a octura x438 or x440.
                      The weight does help to keep the boat on the water at higher speeds.
                      Balancing the boat right is also very important. I would suggest a 43 percent cg.
                      That is measure 10.25 inches from the rear and let that be the balance point.
                      You should have neutral trim to start.
                      • jacob9783
                        • Jun 2019
                        • 6
                        Thank you speed3! 2050kv it is. i'll get both props and play around with them. Ive never thought of balancing the boat. Im doing some reading on how to do that. Thank you for your help.
