Hi guys,
I have an Osprey mono with following specs:
Turnigy 56 series motor (1320kv I think)
Swordfish 240A ESC
Zop Power 6S 4000mah 60C (2 in parallel)
452 prop
I took the boat for its first run the other day, and I keep having an issue with the boat briefly cutting out every second-it sounds as though it's changing gears. Very occasionally it may get on plane and allow full power for approx 4 seconds before cutting out again.
Bringing the boat back in to check temps I recorded the following (all temps in degrees Celsius):
ESC: 75
ESC Capacitors: 105
Motor: 40
If you look at the rooster tail you'll see it constantly cutting out. Toward the end it gets a solid run of about 4 seconds.
What is going on here? I was reading on a similar thread how the LVC kicks in on the Hobbywing 180, could the same thing be happening on my Swordfish 240? Do I need extra capacitors to ensure a constant flow of current to the motor? Would some type of temperature cutout be kicking in, the capacitors @105C seem extremely hot. Is the prop too big, though a large 56 motor surely should be able to handle it.
Swordfish 240A ESC
452 prop
ESC: 75
ESC Capacitors: 105
Motor: 40
