info on 3674-B-2200kv
This topic is closed.
  • Norwest
    • Mar 2014
    • 165
    I now it's old but I never used it till now. Voltage range of 5.5 round connectors is what! Thank you!
  • rol243
    • Apr 2017
    • 1038
    so what are you wanting to know ? if its voltage , this motor is good for a 4s battery set up and a 180 amp esc.
    • Norwest
      • Mar 2014
      • 165
      • rol243
        • Apr 2017
        • 1038
        so what are you wanting to do , blow the motor up ? use 5 to 6 mm bullets and forget those high voltages as your only needing around 14 volts to run with this size motor. [ 4s battery pack ]
        • Norwest
          • Mar 2014
          • 165
          WOW! Your off as I was looking for the voltage 5.5 bullet connectors. Now on Aquastar esc starts of slow and then moves out real good. The directions say if this happens to check the system and most likely , the connectors are not allowing enough current to get to motor. Now I asked what is the voltage range of 5.5mm bullets. Moderator close said thread!!!!!!!!!!!!!!!!!
          • Doby
            KANADA RULES!
            • 7280
            As best as i can figure out what is being asked here....i use 5.5 bullets on 10S with no issues.
            Grand River Marine Modellers
            • rol243
              • Apr 2017
              • 1038
              yes its abit hard to understand what this guy is trying to say. maybe he means to say AMPS not Volts. you dont have any issues using 5.5 mm connectors as long as the soldering is good.
