Anyone solder there on the wires? Do you remove bullets from housing? I've ruined 2 of them from melting housings with bullets inside. Thanks for any and all help. I do know I suck at soldering lol
Ose 8mm anti spark connectors
Tags: None
No, the bullets are not removable. I used a hot iron, about 750*F and tinned the wires and cups separately first. I attached the matching plug to the one I was soldering to act as a heat sink and pinched the connector that matching connector with a needle nose vice grip to take a little more of the heat. I only ran into trouble when I screwed up the polarity on one pack and had to redo the connections. The plastic got a little mushy.
One tip I learned recently was to dunk the entire plug in water to quench the heat. Didn't need to use it on my marathon soldering session, but I will try it out next time.
2019-07-27 16.41.48.jpg 2019-07-27 16.05.37.jpgVac-U-Tug Jr (13mph)
