Deltaforce pathfinder, TP 4030 2450kv, a pair of giant power 4S 4000mah packs in parallel. I was a little confused by the NAMBA rule book some Im not sure what this setup would run in. I want to build a course boat and start racing, I thought a 4S cat would be a good place to start.
P cat setup?
The DF Pathfinder 28 would be legal for racing in P Catamaran and P Offshore with your setup. It is a relatively small hull and could be at a disadvantage racing with other boats in rough water. That said it would still be an excellent boat with which to begin racing. Where in Texas are you located and with whom would you be racing?
Ya know a smaller faster boat can win races in a good drivers hands. The younger drivers with faster reactions beat me off and on in P LTD classes.Comment
I might know a little about setting up a P cat. I have set up the 2 lap records for cats in NAMBA & IMPBA. My son does most of the driving for records. Anyway the DF 28 has done well as a P/limited hull for us. You would be better off going to a 3660 motor for that NAMBA class assuming the new rule passed. As for a full "P" the DF will run fast in a straight line but not corner well above 50-55mph. We used an Aeromarine MM for the IMPBA record and same problem with corner speed. I actually prefer the DF28 over the MM. For a larger motor the TFL Cheetah 34 would be better. In NAMBA you can use a twin for P but again top speed is not what wins races, corners are where you win. Without a major cost going to the limited setup and using 442/3 blade CNC, Octura 642 or cut down M445, or an ABC 1714-1715 will run your DF well. Stay lower on KV in the 1800-2200 range. Higher KV will limit your prop selection to smaller diameters.
MicLast edited by HTVboats; 07-05-2019, 11:51 AM.
Mic Halbrehder
IMPBA 8656
NAMBA 1414Comment
MicComment
If the OP wants to race with the HOTMBC he needs to check with them for the “Limited” motors they will accept. This may differ from some on-line list. The club runs both Limited and full P classes, when I ran there the Miss Geico cats were popular in Limited, the Cheetah was becoming popular in full P....but again, check with them first.
.Comment
