Max Diameter prop for Leopard 3674 2200 Kv onn 4s?
  • Andris Golts
    • Jan 2011
    • 504
    Hi all getting ready to test my Dunlap W.O.F 30 '' o/b tunnel hull i have a Leopard 3674 2200 kv motor mounted to a O.S. Max lower unit with a Swordfish 220 amp esc and a 5000 mah 4s lipo for battery i was thinking of starting out with x440 2 and 3 blade props and working up. My ? is how large a diameter prop can i safely turn on this set up ? Any and all suggestions welcome. Regards Andris Golts.
  • Nevs
    Sven
    • Sep 2011
    • 164
    Start with 40 mm and make 2mm jumps.
    • 785boats
      Wet Track Racing
      • Nov 2008
      • 3169
      My favorite prop on that size & kv motor is a 440/3 blade that has been about 1/2 detongued.
      • JestDanny
        • Jan 2017
        • 174
        My little P-limited spec tunnels like props with about 2.5 " or 64 mm total pitch, = X640 or P-215. Even though your motor is a bit larger than my smaller 36x60's, I don't think that Leo will spin much more prop than that. X637 =59.2 mm total pitch, does the same as work as a X442 = 58.8 mm total pitch, X640 and P-215 = 64 mm total pitch, an X445 or X446 will get you about the same total pitch 63 / 64 mm. hope that helps
        PROBOAT BlackJack 24", ShockWave 26"
        MRP U-31, 3 tunnels VS1, MRP Bud Light, Dumas HS Sprint
        • Speed3
          • Mar 2017
          • 371
          That leopard 3674 2200 makes good torque, I ran a m545 with one sometime back, acceleration was insane. That motor is rated at 90 amps max and the m545 would have pulled over 120 amps.
          I am referring to 4s running.
          To keep that motor in the manufacture rating you would need to run an x440.
          I did saw type running at that time a pass or 2 and come in. If you doing saw type running I have seen 6s with 42mm props.
