Build in extra capasitors??
  • HeineDenmark
    • Feb 2019
    • 25
    I’ve been wondering. What if you build in one or two extra capasitors on the battery side of the ESC. Won’t they help the ESC in getting enough current when you hit full throttle? I know the ESC allready have them installed, but i’m thinking one or two with 80voltage and with 100.000uf. Some big ones.. They don’t weigh much and they sure would help the batteries.. anyone tried that?
  • StevenBryant
    • Nov 2012
    • 359
    Most circuit and SAW racers I know install capacitor banks, I use Rubicon ZL or ZLH caps, I keep the voltage the same as the ones on the esc. I use 5 caps for circuit and 9 for SAW in the range of 540 to 680 uf per cap. I’ll attach some picture for you shortly
    Sent from my iPad using Tapatalk
    • HeineDenmark
      • Feb 2019
      • 25
      I have to ask.. what does SAW stand for? I think i may be the only guy from Denmark here in this forum 😂
      My 320amp esc can handle 16s but im keeping it at 15s. So maybe i should look for some caps that can handle a minimum of 63v or?? Im calculating that on the 4,2v on each sell when they are fully charged.
      • StevenBryant
        • Nov 2012
        • 359
        Originally posted by HeineDenmark
        I have to ask.. what does SAW stand for? I think i may be the only guy from Denmark here in this forum [emoji23]
        Hello Heine,
        SAW is straight line racing, you make two passes and they take the average speed of the runs, you are not the only boater from Denmark, EmilWilkens is also from Denmark.
        You need to check the caps on the esc and use the same voltage, 63v is too close for 15s I would use higher.
        • HeineDenmark
          • Feb 2019
          • 25
          Holy c**p thats a fast one!
          Mine is still in the making. Blew the shaft and prop at my second test. Didnt even made it to the fine tuning of the prop angle and height. Link below. Reached 116 km/h
          • StevenBryant
            • Nov 2012
            • 359
            https://youtu.be/0T_4tIjd6A8
            That a nice running-boat, what happened to the shaft?
            • StevenBryant
              • Nov 2012
              • 359
              • HeineDenmark
                • Feb 2019
                • 25
                I used a cheap alloy prop from another boat i have. I think i was to weak. Also the strut is not suitable for the high rpms becaus of the small bearings inside. So they burned and blew up the end of the strut, which bended the axel... bummer
                Nice caps there. Think i’ll add that to the boat while waiting for parts..
                • HeineDenmark
                  • Feb 2019
                  • 25
                  Just added a pair of caps. Found two big ones that suited the setup. Below there’s a link to a video of the setup. Dont mind my crapybuild wooden battery trays 😂
                  • HeineDenmark
                    • Feb 2019
                    • 25
                    • NativePaul
                      Greased Weasel
                      • 2759
                      The smaller the caps are the quicker they can charge and discharge, so a bunch of smaller caps is better at smoothing the high frequency voltage ripple that we are trying to protect the ESC from than a couple of big ones, even if they have less total capacitance.
                      • HeineDenmark
                        • Feb 2019
                        • 25
                        Ohh okay. I did’nt know that. Well then i’ll try finding some small ones instead. Thanks for your reply.
                        • NativePaul
                          Greased Weasel
                          • 2759
                          There is a long stickied thread by dr wayne on here that you might want to read. https://forums.offshoreelectrics.com...ght=capacitors
