Setup for a 39'' - 1 meter catamaran ?
  • Alfa Spirit
    • 2131
    I want to build a 39" / 1 meter catamaran with a twin setup, I need help to choose between those :
    2 x 4S, 3660 - 2400kV motors
    2 x 5S, 4060 - 1900kV motors
    Thx
  • ray schrauwen
    • 9471
    What is your goal for this project, speed, sport, racing?
    Those are not very robust motors for a 39" cat.
    • Alfa Spirit
      • 2131
      Fast sport, not SAW
      • Speed3
        • Mar 2017
        • 371
        4060 1900kv 5s would be the better option. Is the 4060 a tp motor?
        If yes. That is a very good motor.
        • Alfa Spirit
          • 2131
          Motors are fine, 2 x NEU 1512 - 1900kV and 2 x Tenschock 3660 2400kV.
          @Speed3 , you prefer 5s batteries, right ?
          • akula
            • Dec 2009
            • 30
            Originally posted by Alfa Spirit
            Fast sport, not SAW
            Have you already dropped your carbon monohull project Alain ?
            It takes place on a shelf to store a 39" catamaran, take care !
            One day, you will build your own boat, I know about it, don't give up
            • Destt
              • Sep 2018
              • 66
              I ordered 4082 1900kv x 2 to spartan [emoji106]
              Driver Toni a. K. a speeder
              • Speed3
                • Mar 2017
                • 371
                5s with a 1900kv would have a lot of advantages over 4s and a 2400kv.
                You would have a little longer runtime.
                Secondly the lower kV would hold rpm better underload resulting in higher speeds.
                So a faster boat with additional runtime and cooler electronics is the benefits of choosing the 1900kv, 5s route.
                • Alfa Spirit
                  • 2131
                  Thanks Sppeed3, 5s batteries look better imho. A single question is about the weight ...
                  • Speed3
                    • Mar 2017
                    • 371
                    Sometime back I ran a leopard 4092 2080 kV on 4s in a revolt and an m545. The best I saw on GPS was 48mph.
                    I also ran the leopard 4092 1730kv in the same boat on 5s with the same m545 and my best was 54mph on GPS.
                    I think this is kind of similar to which to pick, a 2400kv and 4s or a 1900kv and 5s.
                    • Alfa Spirit
                      • 2131
                      Here is the typical setup for a MHZ Mystic 114 cm, 2 x 7S and 2 x NEU Motors 1521.
                      So on a 100 cm catamaran 2 x 5S look right with 2 x NEU Motors 1512 - 1900kV.
                      • Speed3
                        • Mar 2017
                        • 371
                        A cat in the 100cm range would run well with 1512 motors. But if 4082 same size as tp 4050 or 1521 motors were available I would prefer that size over 1512 size motors.
                        • Alfa Spirit
                          • 2131
                          Yes but 1512 are NEU Motors and I use 2 Motors, high quality, enemy of the performance is the weight, I hope this is a good setup ...
