Best flex lube with no liner
  • 30nitro
    • Feb 2018
    • 330
    Been using liners for years... now gonna try no liner...3/16 flex.... any body have a preferred lube..? 3674 4 pole 1900 kv 6s...in a TFL Genesis......Just wondering....Thanks to all....
  • fweasel
    master of some
    • Jul 2016
    • 4286
    I run a 3/16th flex in the stock stainless tube on my Genesis and it runs well with standard proboat marine grease. 91mph on 6S.
    Vac-U-Tug Jr (13mph)
    • RCBoaterGuy
      • Dec 2014
      • 213
      See attached.. been serving me well for many years. Applies to boats with & without liners.
      My MM has wire drive drive(no liner), I lubed it once last year. Twice so far in 19 due to recent upgrades. Probably won't need a re-lube till May / June.
      AQ MiniMono - CopterX 430XL 3550kv BL Outrunner + Seaking(V2) 35A on 2S VERY Fast
      Pro Boat SW26v3 - 2860-2600kv + Seaking(V2) 90A on 3S, Build in Progress
      Pro Boat Stealthwake 23 - Stock For Now - Brushless Down The Road
      • 30nitro
        • Feb 2018
        • 330
        Nice...Thanks for the replys so far..!!
          What ever lube you use, it should be replaced at least after each day you run. Water will get into the stuffing tube, emulsifying the lube with the water. Corrosion will likely follow.
          I have used 70W synthetic automotive gear oil (containing an EP additive) for almost two decades on my boats, set SAW records with it and zero rust. That said, almost anything will work as long as it stays on the cable.
          • Jesse J
            scale FE racer
            • Aug 2008
            • 7117
            EP additive, does that stand for “extra proctective”?
            Wanna try; two decades of rockin the FE world... me want some!!
            "Look good doin' it"
            See the fleet
              EP = Extreme Pressure additive. Because of the low velocity of the sliding surfaces (cable/stuffing tube) in FE drives, an EP additive can reduce both friction and wear. You can either add it to a gear oil (see 1st pic) or like I do get an oil which already has it in its formulation (second pic).
              • fweasel
                master of some
                • Jul 2016
                • 4286
                Fluid, are you running just straight gear oil, or do you mix it with a grease?
                • 30nitro
                  • Feb 2018
                  • 330
                  I'm thinkin mabe EP additive...and green marine grease...??
                  • ray schrauwen
                    • 9472
                    Slick
                    Nortavlag Bulc
