OPINION on broken shaft
  • Speedfreek
    • Apr 2018
    • 276
    Just would like to know what you guys think, happend to this shaft .
    MYSTIC 138 119 MPH so far
  • NativePaul
    Greased Weasel
    • 2761
    My guess is you ran an out of balance prop and/or prop nut and a crack propagated from the bottom left in picture 3 which allowed the shaft to bend and threw it further out of balance and quickly snapped the end off.
    Why are the step downs in shaft diameter there? Deleting them would make for a stronger shaft, or if they have to be there putting a raduis on there inside edges would spread out the stress load a little and make it a bit less failure prone.
    • martin
      • 2887
      What is the diameter of the step down & prop size on that shaft ? is it a 3/16" bore prop. As you are running very large powerfull TP 5850 motors on 12s, also as said a step down with no radius will also break easier. It also looked like there was not enough gap between the drive dog & the stinger to allow for flex wind up.
      • Speedfreek
        • Apr 2018
        • 276
        Prop was a Andy brown ? I would think it would be balanced , Not my shafts and yes I agree that there should be a radius there
        • Speedfreek
          • Apr 2018
          • 276
          Yea 3/16 , I have gone up to the next size now and I machined it so I can have more of a gap too.IMG-20190210-WA0007.jpg
          • Johnc
            • Aug 2015
            • 199
            to me looks like of scarring on that shaft (maybe more grease or more frequent greasing)
            • Johnc
              • Aug 2015
              • 199
              although after thinking about it, it would effect the flex shaft not where it broke, but still in all looks like it should have some grease in there
                • 7673
                That is from the bearing. BTW Speedfreak I run two bearings at each end to carry the load and last longer. Once they wear they could cause a wobble and that may happen quickly with only one bearing. Something I’ve been doing on the step down shafts is run a 1/4” drive dog which locks the prop. Just a theory but I haven’t had a stepdown shaft fail.
                • Speedfreek
                  • Apr 2018
                  • 276
                  This drive does have two bearings at the prop end , I have put the 1/4 drive in there now and I have allowed 6.4 mm of gap too where before it would not allow me to do that , that's what I think happend.
                  • Speedfreek
                    • Apr 2018
                    • 276
                    Yep that's what I think
                    • Speedfreek
                      • Apr 2018
                      • 276
                      So how much would you say a 1/4 drive flex approx 8 in long would contract on eceleration ?
                        • 7673
                        I would not think it would be much. 8” is fairly short. I know my 6” 3/16” have as little as 2mm gap with no issue. It’s all a matter of experimentation to find it. The little white thrust washers can help with this
                        • Speedfreek
                          • Apr 2018
                          • 276
                          it's 7" long close enough i have 6mm gap now and 1/4 dog drive shaft , it better not brake now these props cost to much to loose.
                          • MARK FORREST
                            • Jan 2019
                            • 15
                            whats it out of probably not balanced prop could be a bad bearing too
                            • Speedfreek
                              • Apr 2018
                              • 276
                              Bearings are three runs old , prop was a Andy Brown.
                              I might just put in oil-immersed sintered bronze bushings front and rear less headaches , expecialy in salt water...
