Boat Paint
  • Northwoods
    • Jan 2019
    • 29
    Boat Paint
    I Have 2 Gas 26cc boats I had them painted at a auto collision repair shop , Do not want to pay that price on this one ,, Trying to Paint my DV-20 now ,,,Went to Auto Parts Store get auto spray paint it would not cover in 3 coats so I sanded it down to try again
    What paint do you use ???? on U-Tube best I could find was , Rust-Oleum 2X Ultra Cover Spray Paint // Color Coat and then Clear Coat
    HE WHO DIES WITH THE MOST TOYS WINS
    Russ
    • 7673
    The rustoleum is pretty decent but I’ve been using dupli color a fair bit because of color choices and the fact that my U-pol clear#1 likes it.
    • Johnc
      • Aug 2015
      • 199
      Here's what I found, am using the x2 (black hull, yellow stripes on sides and windows) did a lot of prep (sanding, sanding, sanding after each coat of primer) 1000 grit wet/dry paper (wet, works better). Am through pleased (would like to send pic's but in drying faze as I write this and pic's don't really show it off) Once dry, will apply decals and then do an all over spray with rustoleum x2 triple thick
      • Johnc
        • Aug 2015
        • 199
        Sorry, fat fingers
        Triple thick glaze, then 2 coats (1000 grit sand between) clear then will buff with an auto compound.
        • sammyha
          • Jul 2018
          • 1038
          I used Klass Kote epoxy paint. Bought it on Ebay. I brushed it on over a first coat of full strength epoxy on my wood ML RSX380 rigger. It's a true two part epoxy paint. Very tough, but flexible. No issues with compatibility.
          It can also be sprayed if thinned with Klass Kote reducer using this spray system...
          Preval Preval Val-Pack https://www.amazon.com/dp/B00CW809XQ..._VHxwCbFMMRW85
          I plan on spraying my next boat. I ordered this system...
          Sent from my SM-G950U1 using Tapatalk
          • longballlumber
            • 3132
            If your looking for 2 part epoxy paint, klass kote is an excellent product. I have used it for several years now. If I can shot this stuff anyone can!
