OSE Mini Outboard/HK 3000kv vs. HK 650EP 2630kv.....who's had the best success ?
Outboards...
Tags: None
I tried the HK 650EP on a 26" deep vee, it showed promise, but after suffering broken flex shafts, I abandoned that motor, tossed it in the trash. Several others have also had broken shaft problems with the HK 650EP. I would not recommend the HK 650EP outboard, to bad cause I love the scale looks. I have the OSE Mini 3000kv on a old MRP tunnel, so far so good, no broken shafts after one season and several runs all on 2s. I up graded from stock x432 prop to a x632, boat runs 23mph on 2s, I'm happy with that for now, its an old toy not a race boat. (ha ha lol) Maybe next season I'll try a few different props an also see what it will do on 3s. good luck.PROBOAT BlackJack 24", ShockWave 26"
MRP U-31, 3 tunnels VS1, MRP Bud Light, Dumas HS Sprint -
Thanks JD,
I agree about the looks......I have two builds with the EP650 EP, but have yet to run either. I have a stockpile of spare shafts. I wonder why the breakage rate is so high? I will buy the Mini 3000kv unit soon after the holidays as a backup. I too will probably learn the hard way. Thanks for your response and Merry Christmas !Comment
I’ve got the OSE mini on a little kneeler running on 3s, I was really surprised how fast it is. No problems with shafts so far but haven’t run it a lot.
Sent from my iPhone using TapatalkNamba District 16
1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joes, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.Comment
Very Nice! ......if you look for pics under my user name..."creekrunner" .....you'll see what I've been up toComment
CNC Outboard
IMG_3497.JPGIMG_3493.JPGHey Guys,
I know the feeling about breaking flex shafts with the CNC HK Motor. Broke a couple dozen last summer. I'm going to try to find a stronger one but may end up with changing motors. Just love the scale look of the HK CNC one. The tight 90 degree turn and small dia. shaft is a problem. I'm almost done repainting a plain white Dragon Hobby F1 to look like my friend, Wyatt Nelson's boat. Just need 3 graphics printed on prism tape.
IMG_3183.JPGIMG_3240.JPGIMG_3498.JPGComment
[ATTACH=CONFIG]163183[/ATTACH][ATTACH=CONFIG]163184[/ATTACH]Hey Guys,
[ATTACH=CONFIG]163180[/ATTACH][ATTACH=CONFIG]163181[/ATTACH][ATTACH=CONFIG]163182[/ATTACH]Comment
If I do find a solution to extending the life of these shafts or find a stronger replacement I will certainly share the info. I did replace the Teflon shaft sleeve with 3/16" diameter brass. I think it gave me a couple extra runs. I ran the boats in the upper Niagara River on a sand bar about 2 or 3 feet deep. I set up a 3 bouy course so that I could walk out and recover the prop and dog when it let go.
IMG_3501.JPGIMG_3505.JPGComment
