Electric twin motors for a Central rc marine 51" Victory cat
  • wedgewalker
    • Jul 2014
    • 32
    Can anyone suggest what size motors to go with for a twin set-up. I am currently running a TP 5670 720 kv 5y on 12s. I have the flier model 400a 90v red waterproof esc. I would like to go with two motors and use one esc so I need to keep my amps right at 400 for both motors. This esc is supposed to have a 500a max rating, Is there any way to accomplish this for that hull? I would like to still use 12s, so 1 6s pack per motor.
    Thanks,
    Glen
  • MarkF
    dinogylipos.com
    • Mar 2008
    • 979
    You cannot use 1 esc for 2 motors. For 6s use TP 4070 1520KV ABC 2217 props and swordfish 200a escs.
    Mark
    • wedgewalker
      • Jul 2014
      • 32
      Mark,This esc has six motor wires and 4 power wires, if it can't be used that way is that only because of the capacity?
      • MarkF
        dinogylipos.com
        • Mar 2008
        • 979
        Those are rare to see. My motor selection still stands though.That's what I run in my 6s rigger that does high 80s.
        Mark
        • wedgewalker
          • Jul 2014
          • 32
          Hey Mark! What size hull are you pushing with that set up?
          • MarkF
            dinogylipos.com
            • Mar 2008
            • 979
            38" rigger. Your 51" cat will do very well with my setup. Twin motor setup that is.
            Mark
            • Nevs
              Sven
              • Sep 2011
              • 164
              Just a remark. 6s. is not the best choise. Your lipos will probably have a hard time. So 60C or preferably more would be a good idea....
              • wedgewalker
                • Jul 2014
                • 32
                I have giant power kitty sticks, they are 70c to 140c 6s 6000mah x4, that's two 3s per pack.
                • MarkF
                  dinogylipos.com
                  • Mar 2008
                  • 979
                  The setup I posted is very easy on the equipment. Nothing gets past warm in my boat. A twin will be even easier.
                  Mark
                  • wedgewalker
                    • Jul 2014
                    • 32
                    Should motor timing monitor be on or off in esc?
                    • RaceMechaniX
                      • Sep 2007
                      • 2821
                      Assuming you are not trying to run a class legal set-up, you can run 12S1P and feed both ESC's with the single battery using the same motors. Just prop accordingly.
                      Tyler Garrard
                      NAMBA 639/IMPBA 20525
                      T-Hydro @ 142.94mph former WR
                      • wedgewalker
                        • Jul 2014
                        • 32
                        Hey Tyler, Thanks! If you saw in my previous post I have a Flier ESC That has six motor wires and 4 battery wires. Can that be for two motors or is it just for high amp setup. I also was wondering if the timing monitor should be on or off in the ESC?
                        • RaceMechaniX
                          • Sep 2007
                          • 2821
                          Those double ESC's are just two singles placed back to back. They should be connected to two motors individually. You should not try to operate the double ESC connected to a single motor.
                          you can run both off a single battery if the amp draw on the battery is reasonable.
                          Tyler Garrard
                          • wedgewalker
                            • Jul 2014
                            • 32
                            Ok, I am running a TP 5670 720kv 5Y with that esc. So I should only run off one half of it for 12s or should I get a different esc. My plan is to run two TP 4070s w/6s on each motor and stick with that same setup.
                            • wedgewalker
                              • Jul 2014
                              • 32
                              thumbnail.jpg 1.jpgVictory Cat.jpgHere is my setup, seems to be running just fine with single motor.
