Yep, you have to find that happy medium. Sometimes dropping the prop makes the hull faster but it also will cause the motor and cells to run hotter. I usuallyt start with a high strut and work my way down until it runs to hot and them back off a bit.
The more you drop the strut the weter the ride pads are. This will stop blow over and slow you down and make the boat harder to push foward. If you watch the boat run and look at the ride pads as it goes in front of you, you do not want to see any water beeing pushed foward. You allso look for about one inch to 3/4" of water on the rear of the ride pad. Any more than that and you are too wet.
I look for 3.5 to 6.5 degrees of lift depending on the applacation.
Randy
For ABS, Fiberglass, Carbon hulls and Stainless hardware BBY Racing
OK this is how I do it I take a board big enough to place the boat on and level it all directions. This board is called a set up board. It has cut outs for the rudder and the turn fin and set up so the sponson hangs off the side of the board. Then I take a Protractor and place it on the rear 3 inches of the ride pad. Then I can read the degrees of the sponson attack. This is called inclination. If you turn the protractor 90 degrees then you are measuring the dihedral. The dihedral also will control your speed the flatter the faster. But the more angle the faster in the turns to a point, if you put too much dihedral in the sponson speed will be lost. 1.5 degrees is my max. I will take a picture at work and post it.
Randy
Randy, I searched an explanation for dihedral and now I am totally confused. I believe it refers to the angle between the sponsons or wings. How do you adjust this angle on fixed sponsons? Or does the strut angle and depth make the difference.
Douggie
It is adust in the building of the boat and is a fixed angel on both sides of the sponsons of the bottom of the ride pads. If you were to look at the boat from the rear, the angle that the sponson rises is the dihedral.
Sorry I got carried away, As you know I am all about design of boats, it is one of my passions.
More pictures later.
Randy
I cannot understand it but don't worry. I guess this is used in hydros. For the word dihedral i can translate from greek as:
di=means two (dyo in greek)
hedral= means a seat (like exhaust valve seat) (hedra in greek)
Thanks for your rely.
Randy, thanks for the answer and I trust all is well after your surgery. Take care and thanks for your major contributions to Fe boating.
Douggie
You are welcome It means a lot to me.
I have been out from surgery about 6 weeks. It was a tough one, I am 95% recovered. I have some Blood vessel that were damaged and are regrowing them selfs this takes a while. Strange my dentist friend expalined to me better than the Surgen.
Randy
I wish I was good at Photo shop to draw lines to help, sorry
Randy
Randy I took your picture and put a few lines on it to show the dihedral. I hope you do not mind.
The dihedral is the angle between the two red lines.
David explains it very well.
