My JAE33 FE
  • blackout
    • Sep 2010
    • 10
    My JAE33 FE
    Here is where I'm at now. This is my second brushless FE build. Previous boats were mostly nitro. Motor is a TP3640 1935kv. It will run on 4s.
    Craig Mapstone
  • larryrose11
    • Jun 2010
    • 757
    Others here on the forum have run tp motors near their max voltage witth smallish props for the given hull to good success.
    He was running a 4060 1650kv, on 8S with an X646 prop.
    For your motor, max voltage 31V.
    Once you get more experience, 6S and a smallish prop could be an option for more speed.
    Here is the reference thread.
    https://forums.offshoreelectrics.com...s-enough-power
    • Nevs
      Sven
      • Sep 2011
      • 164
      Nice build. I think you will have great fun with that setup. Good speed. Good runtime. just a question. How wide is the mid section ?
      • blackout
        • Sep 2010
        • 10
        I will have to check when I get home tonight. The tub is wider than the nitro JAE 21's I have. Plenty of room for batteries and such.
        • blackout
          • Sep 2010
          • 10
          Outside width is 3.75". Tub walls are 1/8" thick ply.
          • Nevs
            Sven
            • Sep 2011
            • 164
            Thank you very very much.
            • RobCoba
              • Sep 2018
              • 1
              So any pics of the end result love to see what paint job you went with.
              • ray schrauwen
                • 9475
                Is there a specific reason to use ZPOxy to build this or is West Systems o.k. or too heavy????
                Nortavlag Bulc
                  Z-Poxy Finishing Resin is easy to find and easier to mix, and cheaper for a few builds. West may be better quality, but Z-Poxy is fine.
                  • blackout
                    • Sep 2010
                    • 10
                    Sorry for the delay... Ran the boat all spring, but 2 weeks ago, the drive shaft tube failed under the ski. So need to replace that, which means cutting the ski off I guess. First time I have had that problem. My 21 Zippkit JAE is several years old and has seen MANY races and crashes. But anyways, here is a pic I took just before it's maiden voyage. No special paint job. lol Cowl is painted yellow now.
                      Why did you mount the rudder on the opposite side recommended in the manual!
                      • blackout
                        • Sep 2010
                        • 10
                        Any drag the rudder creates will help counter the drag from the turn fin. It's small, but the JAE riggers turn awesome with the rudder on either side. I have built a .21, .45, .91, and a gas.
