Is there a Popular budget waterproof servo for FE? How many oz Torque are required?
  • rotarypower101
    • Feb 2009
    • 23
    Have been using basic servos with corrosionX and grease but still had issues, but then moved to a waterproof HPI servo, which seemed to have really helped on one of the boats.
    Is there a good “go to servo” that is waterproof out of the box that is also pretty reasonably priced for the offering?
    What range of torque should I be looking for for a boat with the basic following setup?
    Will a low/basic torque servo be fine in the following scenerio, or are there any benisits to be found with a stronger servo?
    Used exclusively for recreational play.
    For a Genesis hull on 4S Octura X442
    Standard lay down servo configuration, and stock center mounted rudder.
    Are there any of the Savox waterproof servos that would be recommended ? Are they OK?
  • JimClark
    • 5907
    I never had issues with regular servos and using corrosion x on them. I reapplied corrosion x after each day or racing and left the servos open to totally dry out also. I even applied it to the connector
    Sent from my Moto G (4) using Tapatalk
    Billy Graham
    • 30nitro
      • Feb 2018
      • 330
      Well....I've had very good luck with the KS-3518 digital high torque metal gear servo ...water proof from Flea bay.......
      • RaceMechaniX
        • Sep 2007
        • 2833
        The Hitech D646WP is a pretty good buy at $55 for a 180oz servo that is water proof. https://www.servocity.com/d646wp-servo
        There is also the HS-646WP with 160oz. https://www.servocity.com/hs-646wp-servo
        Tyler Garrard
        NAMBA 639/IMPBA 20525
        T-Hydro @ 142.94mph former WR
        • photohoward1
          • 1611
          Better question why are they getting wet?
            An FE boat should be dry inside, as Howard stated why is there enough water in the boat to effect a treated servo?
            For a 4S Genesis any servo with at least 80 oz-in will be plenty.
            • rol243
              • Apr 2017
              • 1038
              Savox make excellent servos and there Blue Case waterproof 15kg is cheap and very good.
              • enzo thecat
                • Jul 2013
                • 42
                My recommendation is Savox. I will only use Savox in my boats, even my large scale gas and electrics. They have been extremely reliable. With that said, I have been using the high torque, high speed digital waterproof ones. They are only budget friendly when you realize that will be the last servo you buy for a long time.
