Mono with battery puffing problems
  • enzo thecat
    • Jul 2013
    • 42
    I have a mono (CF Ariana 2) with a leopard motor (that I upgraded from the original motor) and I've run Thunderpower 6S batteries with pretty high C ratings (50-70C). I've tried about 4 batteries and all of them get hot and puff on short runs well before the esc voltage protector kicks in. So something is mismatched. It can either be the motor, the prop, the esc or the batteries but I tried several batteries of different combination and they all do the same even when brand new. Where should I start? The prop is stock and worked fine with the weaker stock motor that was provided with the boat.
    e
  • ETOWNE
    • Mar 2008
    • 250
    Need the mah on batteries, how many and how they are wired if running multiple packs, what leopard motor, and prop . And swelling packs is from too much amp draw.
    Vortex 22 hydro ammo 36-50
    Vortex Cyber Storm 33 P spec Mono AC 36-56
    PT SS-45 Q-hydro Neu 1527/1Y
    • enzo thecat
      • Jul 2013
      • 42
      Thank you for helping.
      Motor: Leopard 4092 Motor winds/rpm - 1730Kv 3D
      ESC: HK Seaking 180A
      Battery: 6S 5000mah 55C
      I am not sure of the prop. It is the one that came with the boat. IIRC, I bought several props but couldnt find one that fit this China setup. Its been a while because I get so discouraged from damaging batteries every time I try. My fix has been to upgrade the batteries but that isnt working.
      • boatsrnew2me
        • Oct 2016
        • 476
        incorrect timing comes to mind .that can heat everything up .
        whats your low voltage cutoff set at? if at all? this should be kicking in way before your lipos start puffing up on you .
        what brand lipo? how old are they??
        and we really need to know the prop to help more .
        are you leaving a gap between the drive dog and the strut to allow for flex wind up?
        what connectors on your lipos?
        volantex vector pro ,proboat veles 29 , traxxas spartan, hobbyking/tfl pursuit ,ft009 with rescue rigging
        • ETOWNE
          • Mar 2008
          • 250
          I can’t speak for that hull and motor. Seems like a pretty high kv for 6s. Thanks boatsrnew2me.
          • rol243
            • Apr 2017
            • 1038
            yes the kv,s will certainly assist in puffing up the packs. a 1600 kv max is ok for 6s but when you go higher in kv,s then things will get warm and or overloaded. i went through this with a 4s set up with the pack getting hot and puffy, only to be told my motor kv,s were too high for the 4s set up. you either swap to a lower kv motor or you could try a smaller prop and see how things go.
            • enzo thecat
              • Jul 2013
              • 42
              Thunder Power Lipos. All were heating and puffing from Brand New
              Yes there is the proper gap between the drive dog and strut (I should have mentioned that, thanks)
              Deans Connectors between battery and esc. Large bullets between motor and esc (Came with motor)
              TIMING: Timing is 0.00
              Low Voltage cutoff is 3.2V Cell
              • boatsrnew2me
                • Oct 2016
                • 476
                first issue i see (and its a big one) is the deans connectors .they are only good for passing 50-60 amps .people have ran more thru them but this is the result .
                first thing would do is upgrade to ec5`s are something similar . i use ec5`s on all my boats and never have a problem .
                i done a little digging and found this too-The 4092 - 1730kv is a D wind motor,on a Seaking 180a set to 3.75 degrees.
                that alone isnt a big difference but i bet you sure could use better connectors .
                are the wires pretty hot when you bring it in ?
                also the lead length coming off the esc -shorter is better .
                i would start with a connector upgrade and report back ,everything else seems to be in order .oh ,we still dont know the size of your prop...that could be a big factor as well.
                • enzo thecat
                  • Jul 2013
                  • 42
                  Wires a little warm. Definitely not hot. Just ordered 6.5mm Castle Creations Bullets.
                  Prop:
                  • boatsrnew2me
                    • Oct 2016
                    • 476
                    no mark on the end of prop? its 45mm so its either a 645 or a 445 .i would start at the connectors and go from there .that seems to be the biggest bottleneck
                    • enzo thecat
                      • Jul 2013
                      • 42
                      Update: I discovered I had Castle 6.5mm connectors in my stash and I just finished converting all the deans to 6.5mm bullets. Hopefully that will be the magic fix. Thanks for the suggestions.
                      • boatsrnew2me
                        • Oct 2016
                        • 476
                        good luck and report back
                        • fweasel
                          master of some
                          • Jul 2016
                          • 4286
                          FYI, if your Castle connectors are impossibly tight fitting, I give the male ends a light squeeze with a needle nose pliers at 12/6 o'clock and again at 9/3 o'clock. It doesn't take much pressure and saves a lot of frustration.
                          Vac-U-Tug Jr (13mph)
                          • enzo thecat
                            • Jul 2013
                            • 42
                            Thank you fweasel .
                            • stadiumyamaha
                              • 1284
                              That's a lot of prop to spin for any length of time at over 40k rpm.
                              After swapping out connectors Id try either propping down or lower voltage.
                              Your setup would make a solid 4s setup with that prob and would achieve a few things for you. It would allow you to work on your setup, cure the amp problem and be a lot of fun instead of a lot of frustration. No, it wont be a 60mph boat but it would be a great 40-50mph boat that handles well. You could possible push it to 5s but Id keep a close eye on temps.
                              Here's a vid of my pursuit with a similar setup running on 4s. One of my favorites builds and still running on the same equipment that it was in the video from years ago. I've had a lot of other guys smoke equipment trying to keep up with my little 4s setup. LOL
                              JMO I could be wrong.
                              white geico w/2200kv 3674 leopard 53.5mph 4s2p, geico w/ 1800kv outrunner 52mph on 4s2p, genesis w/2200kv castle 53.8 on 4s2p, impulse 31 w/2200kv castle, stock p1 and ul-1
