phil thomas ss45
  • betapro
    • May 2017
    • 16
    phil thomas ss45
    i have a Phil Thomas super sport 45 it s has never been run,i want to run it on 6s , the motor i have for it is a neu 1527 1y , 1250kv , the guys in my club run leopard 4082 1600kv motors on 6s for q hydro class , my question is , will i be able to keep up with them , will my boat be fast enough , if not, what motor would you guys recommend and with what prop .
  • Raydee
    • May 2007
    • 1603
    I don't race but mine goes pretty well on that setup using 6 sup swinging a 52mm prop.
    Sent from my SM-T320 using Tapatalk
    Team Liquid Dash
    • rol243
      • Apr 2017
      • 1038
      with your lower kv motor you can swing a larger prop so speeds will be equal to the guys that run higher kv motors with smaller props.
      • NativePaul
        Greased Weasel
        • 2760
        You will have the power, but it is a big ask for a sport hydro to keep with riggers in the hydro class.
        • rol243
          • Apr 2017
          • 1038
          think he is talking Q class sport hydro not rigger hydro.
          • madmikepags
            • Aug 2012
            • 1359
            That hull w a 1527/1Y w a 457 2 blade (tongue reduction, and pitched to 4.5") will haul the mail. Thats the setup I used in my .40 whip (that weighs twice as much) to run a record 6 lap run.
            We call ourselves the "Q"
            • madmikepags
              • Aug 2012
              • 1359
              I ran mine w only 6000mah because of space restriction in my hull, but I would recommend at least 8000mah
              • rol243
                • Apr 2017
                • 1038
                I am setting up a new 6s sport hydro with T.P. 4060-1240 kv motor, both the prather 240 x 2 or the octura 455 seem to work well . I think the larger 457 moded prop might be too much for us running a single 6s pack [ not 6s2p ] sounds good though madmikepags.
                • Raydee
                  • May 2007
                  • 1603
                  I have ran up to a 452 prop on my PT 45 with 6s2p 8800mah and I would say for my setup that is about as hot as I would want to run it and still have good runtime. I am using a Neu 1527 1Y 1250kv motor in mine.
                  Team Liquid Dash
                  • betapro
                    • May 2017
                    • 16
                    thanks guys , i will run two 5000 mah 6s , with an octura 450 and test run it with bigger props for 1 lap ,to see where the temps go
                    • rol243
                      • Apr 2017
                      • 1038
                      a club mate is running a prather 240 which has more pitch and diameter than the 455 octura and his set up with a 1250 motor and single 6s pack runs cool for 6 race laps. its definetly the go to start off small and work your way up in sizes.
                      • 785boats
                        Wet Track Racing
                        • Nov 2008
                        • 3169
                        I too, ran a Prather s240 on 6s with that motor. A 447/3 also works well.
                        Again, as rol243 stated, these are on 1P setups only for racing here in Australia.
                        • Shooter
                          Team Mojo
                          • Jun 2009
                          • 2558
                          That is a tried and true set up. 1527, 452, (2) 5000mah 6S's. I ran the castle 240.
                          • Navherc130
                            • Sep 2013
                            • 151
                            Hey madmikepags, what esc or amp range would you recommend for the above setup? How long a runtime with 6000 mah? With the 457 2 blade? Thanks
                            • madmikepags
                              • Aug 2012
                              • 1359
                              at least a 200 amp speedo, my runtime is a race time between a minute 10 and a minute 30. This is a RACE setup not a sport running setup.
