This may read out as stupid but if you have a brushed motor with limits at 12 v on a lipo battery. The lvc at 3.5 on 3S which gives you 10.5 and lipo will be 12v, how much time can boat be run before you can safely bring it in? Lipos are fairly new, thanks for your time in answering! Boat is a 27" roundnose, made from a kit I put together ( bought ).
Time limit
There are too many variables to be able to give an accurate answer to that question. The primary one being the capacity of the lipo. We would at least need to know that.
All you can do is run it for a set time, maybe two minutes if the pack is around the 5000mah size, & then check the voltage/capacity remaining in the pack. If there is still say, 50% left run it for another minute and check it again. Repeat until there is still 20% -25% capacity left in the pack.
Never run a pack below 20% capacity left or you will damage the packs.
Here's a chart that will help.
A cell checker is the best way to monitor your packs after each run.
Without fail, the first thing I do when I pull a boat from the water is check the battery.
It will measure pack voltage & capacity, and individual cell voltages & capacities.
https://www.offshoreelectrics.com/pr...emp-eossentry3See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320 -
The voltages in that chart are resting voltages, dont forget that in use the load will bring the voltage down below that temporarily, and it will take some time for the pack to recover back to its resting voltage.Paul Upton-Taylor, Greased Weasel Racing.Comment
Paul is absolutely correct.
If the cells are run down to about 3.5V each under load, the resting voltage will come up to around 3.7V/cell in a few minutes.
But I don't understand what you mean by you only have 84 to play with. 84 what?
What size battery do you have?
A 5000mah on a setup suitable for a 27" hydroplane should run for around 4 minutes. But that will depend on your motor size & kv, & your prop size.
Tell us your lipo size, motor size & kv rating, & the prop you have.
It will make it so much easier to answer your original question more accurately.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
This is the second time I typed a response to tell you everything I did and more. I'm teed off now and lets forget I posted, have a good day! They say I wasn't legal to post but I signed in with name and password and log in and they say i'm illegal. Thanks for your help and will put a outrunner 2836-2700 on 3S in and with such a long flex, i'll drop down to a 632 and my guess of rpm will be around 26000 for me. Again thanks gentlemen! This has happened more times than I like and will cease posting and just read. I've been in this hobby since 95 and love it. Been nice typing with you people!Comment
That sounds like a good setup, you should get somewhere in the region on 4 minutes on a 3s 2200mAh if it is running nice and loose.Paul Upton-Taylor, Greased Weasel Racing.Comment
Actually i take that back, I missed that it was 27", I was incorrectly assuming from the motor size and cell count that it was closer to the 20" range, I would say it is undersize for a 27". You have more chance with an x435 than an X632, but a 36mm 2000ish KV motor and 4s 5000mAh pack would be more apropriate.Paul Upton-Taylor, Greased Weasel Racing.Comment
Thanks for replying. I worked on the motor mount and moved it more to the transom. I put the 2700 in with 2 3S just to find out the cg and was way off, so your suggestion is most likely in the ball park. I'm giving the neck and back a rest. I have a motor that size and a 2030 too. I'll find out more tomorrow.Comment
