Twin setups
  • Raydee
    • May 2007
    • 1603
    Twin setups
    This is my first time in over 25 plus years of RC boating that I am going to give twin drives a shot. I plan to run one 6s pack to each esc and I am wondering if that will work good. I am concerned that since I mainly run around bouys and turn right that one esc and motor will work harder than the other and in turn one battery will get worked harder also.
    Sent from my SM-N950U using Tapatalk
    Team Liquid Dash
  • StevenBryant
    • Nov 2012
    • 359
    To solve the issue of the batteries use esc with two battery wires and connect both esc to both batteries, this should keep the load equal on both cells.
    • Prodrvr
      • Jul 2015
      • 701
      Wow!! 25 years and this will be your first twin? Man, you've been missing out!
      • Raydee
        • May 2007
        • 1603
        Yeah I really never saw the need for two of everything but decided it's time to give it a try.
        So is this basically what I will have to do to parallel the esc's?
        Team Liquid Dash
        • MarkF
          dinogylipos.com
          • Mar 2008
          • 979
          Yes that is correct.
          Mark
          • Prodrvr
            • Jul 2015
            • 701
            Two of anything is always better...incomes, women, cars lol
            • TRUCKPULL
              • 2971
              Ray
              I have doing it for three years now.
              Q cat two years ago 69MPH.
              Log into Facebook to start sharing and connecting with your friends, family, and people you know.
              With a few changes it is now running 77MPH
              First place at the IMPBA Can- Am race this year.
              Larry
              • Raydee
                • May 2007
                • 1603
                Larry the link doesn't work. Do you also parallel the esc's in your setup?
                Team Liquid Dash
                • TRUCKPULL
                  • 2971
                  YES
                  Also put a plug in the black wire between the two ESC's, because you will want to disconnect them from each other to program them.
                  Larry
                  • Prodrvr
                    • Jul 2015
                    • 701
                    I'm assuming all the in line fuses in that schematic are omitted.
                    • royalcasa
                      • Mar 2014
                      • 560
                      Not sure about women, there goes your double income. Lol
                      • Raydee
                        • May 2007
                        • 1603
                        Yeah that's not my drawing, I got it from the net.
                        Team Liquid Dash
                        • madmikepags
                          • Aug 2012
                          • 1359
                          What hull are you using, a cat I presume, and how are you configuring your props. The way larry does it with the props out the sponsons it makes sense to parallel the batts, and speedos, but if the props are near the center of the boat, first you don't need to parallel the batts or speedos, and there is no need to run counter rotating props. I have done extensive practice with this setup, as larry has done on his setup. 2 different ways to skin a "CAT" pun intended!!!!!
                          We call ourselves the "Q"
                          • Raydee
                            • May 2007
                            • 1603
                            Mike, its a cat and the props are out on the sponsons. I have seen the nitro rigger guys run twin setups without counter rotating the props with great success.
                            Team Liquid Dash
                            • grsboats
                              • Jul 2012
                              • 975
                              My Twin FE rigger do not use counter rotating props and runs really strong.In this case it is important to mount the struts with offset to compensate the overveer caused by the propwalk,btw you have a large selection of left props to test.Gill
                              GO FAST AND TURN RIGHT !
                              www.grsboats.com.br
