Hi all over the last 4 weeks set up the Dunlap 30'' tunnelhull with the Leopard 4082 1600 KV motor and 6s 5000 mah 40c lipo testing props in the 40-42 mm range . This set-up is a real handfull in windy and choppy conditions with max speeds in the 49-51 mph range tonight the water was perfectly flat with no wind i pinned the throttle the gps read 59.3 mph using a Octura x440 /3 prop. Im considering going back to 4s and try a 3674 motor in the 2000 kv range and once again thanks to Mic and all the others who helped me with my setting this boat up. Regards Andris Golts.
Testing W.O.F 30'' O/B tunnel ON 6S POWER.
Tags: None
Hi nitro 30 the Dunlap W.O.F 30 is set up with a outboard O.S max lower unit with the conversion plate for b/l motors i never imagined this lower unit could handle this kind of hp i was told the b/l power im putting through this unit is comparitive to a modified .45 nitro engine. Regards Andris GoltsComment
7.5cc power thru a 3.5cc lower awesome! What ESC are you using, did I miss that? Did you try any higher pitch props X640, P-215, maybe X642 on my little p-limited tunnels I really like those props, adds a couple a mph over the 1.4 pitch props. I run P-limited 36x60 mm, 2030/kv power(mid 40's mph) on 3.5cc K&B's, bullet proof little sport lowers. Any pictures?PROBOAT BlackJack 24", ShockWave 26"
MRP U-31, 3 tunnels VS1, MRP Bud Light, Dumas HS SprintComment
