60 cm / 23'' Catamaran, setup question
  • Alfa Spirit
    • 2131
    I need help to choose a setup for this catamaran, 3S or 4S ? Motor size ? RPM unload ?
  • rol243
    • Apr 2017
    • 1038
    Are you wanting this hull for speed or fun ?
    • Alfa Spirit
      • 2131
      I want a fun and fast cat
      • Alfa Spirit
        • 2131
        Looking to the size of the hull (60 cm / 23'' Catamaran) the most important is what kind of battery choosing, 3S or 4S ?
        • Speed3
          • Mar 2017
          • 371
          The leopard 2860 series are good motors for smaller boats.
          Can turn props in the 36mm range at good rpm under load.
          The 3400kv if you want to use 3s.
          If you want to run a 4s a 2500ish kv.
          For your prop something like an x435 should be a good choice.
          • Old School
            • Aug 2017
            • 686
            My son has the following in a 26" Flowmaster -
            TP Pro Comp 2940 7Y 1790kv
            Hobbywing Seaking Pro 120 amp ESC
            3919 CNC propellor
            6s (2X3s) Graphene batteries
            The boat has telemetry and the last recorded speed was 93 klm/hour before running out of pond. The stock strut was modified to run a 4mm rotating bushing, plus the hull had a carbon fibre inlay.
            • NativePaul
              Greased Weasel
              • 2760
              Wow.
              I agree with Speed3!
