Transom hardware set up questions DF 26 Mono
  • StephenLilly
    • Aug 2018
    • 33
    I've gotten nearly all the parts and hardware for my first mono/electric build and am ready to start drilling holes! In my Delta force 26 mono, is there a standard on stinger strut placement in relation to the keel, I guess the important measurement is stuffing tube center point for the drill hole. Also I am asking for help on trim tab placement, flush with the bottom of the boat and about the importance of how far away from the keel towards the side of the boat? And also turn fins and rudder depth if there's anything I should know about those or other things I should consider. Thank you!
    • 7673
    I have one in the attic. It runs great but I lost the lid. I’ll get up there and get it down for pics/measurements.
    Shawn
    • StephenLilly
      • Aug 2018
      • 33
      Great, that would be awesome!
        • 7673
        Propshaft hole is 5/16” up and this one had trim but doesn’t now. Doesn’t need them either. Bolts are there so I can get measurements.
          • 7673
          Oops forgot about the lousy phone pic upload thing. Just save the image and rotate.
          • fweasel
            master of some
            • Jul 2016
            • 4286
            Shawn, pics of the inside? I bought a fiberglass replacement hatch for my carbon hull last summer, fits great. If you decide you want to run that boat again, Steven can order one for you.
            Vac-U-Tug Jr (13mph)
              • 7673
              Sure Ryan, as you can see it was a custom paint job(reason I bought it) so it went to the attic out of my sight for a time.
              • Luck as a Constant
                Make Total Destroy
                • Mar 2014
                • 1952
                i mounted my strut up about 3-4mm from the bottom (meaning the bottom of strut was about 3-4mm from bottom of transom). trim tabs maybe 2mm up and fairly close to strut. trim tabs as far out as i could mount. ill post up pics and vid later today for ya.
                  Make Total Destroy
                  • Mar 2014
                  • 1952
                  you can see i used a flooded tube, but either way you get the idea IMG_1651.jpg
                  heres a vid too
                    Make Total Destroy
                    • Mar 2014
                    • 1952
                    couple more
                    • StephenLilly
                      • Aug 2018
                      • 33
                      Ok, great you all, thanks so much for the info and the pictures are a huge help also! With the turn fins, it looks like they should be perpendicular to the bottom of the boat?
                        Make Total Destroy
                        • Mar 2014
                        • 1952
                        Yep 👍🏼
