leopard 4082 1600kv replacement
  • urbs00007
    • Jun 2011
    • 826
    looking to replace my leopards 4082 1600 kv on 5s. they are in my aeromarine 36" cat. what t.p. motor would be a bolt- in replacement. the mount is an ose angled mount. thanks
  • rol243
    • Apr 2017
    • 1038
    have a look at the T.P. 4070 sizes.
    • ray schrauwen
      • 9472
      What esc ??
      Nortavlag Bulc
      • TRUCKPULL
        • 2969
        For a motor the same size and KV --- better made, more reliable, and more power.
        TP 4050 - 40mm X 83mm
        1577 KV - 4Y
        I run a pair of these in my Twin Aeromarine 36" Avenger Cat but in a 6S2P setup.
        77 Mph - set up for oval racing.
        First place at the IMPBA - CAN-AM race two weeks ago.
        If you are going to stay with the 5S setup you may want to go with the 1700KV - 7D motor, or even a 1950Kv - 6D for short runs (2 MIN. MAX)
        Larry
        • urbs00007
          • Jun 2011
          • 826
          1577 KV - 4Y
          Larry
          that must be a beast at 77 mph. on 5s I should get high 60's ??
          • urbs00007
            • Jun 2011
            • 826
            What esc ??
            seaking 180's.
            • TRUCKPULL
              • 2969
              If you want high 60's. on 5S - the 1577 Kv will not get you there.
              Larry
              • rol243
                • Apr 2017
                • 1038
                The twin cats are certainly quick boats. One of our club members runs a twin and its in the low 70,s plus it handles the turns very well. hey Paul.
                • 785boats
                  Wet Track Racing
                  • Nov 2008
                  • 3169
                  Not sure on the top speed Roland. I've never had a GPS in it. Should try it one day.
                  • rol243
                    • Apr 2017
                    • 1038
                    It would be in the low 70,s Paul. you,ve only seen your hull running at speed up high in the drivers stand area not at water level .
                    • urbs00007
                      • Jun 2011
                      • 826
                      is the tp motor the only choice besides leopard to replace these motors, tp only come in 8mm shaft. would like to avoid changing collets if possible.
                      • TRUCKPULL
                        • 2969
                        Where do you get your information??
                        https://www.offshoreelectrics.com/pr...rod=tp-4050-v1
                        5MM shaft with flat spots.
                        Larry
                        • urbs00007
                          • Jun 2011
                          • 826
                          Larry
                          post #2 said 4070. I assumed all other posts were the same motor. my bad. thanks for spotting that error.
                          • emspjay
                            • Sep 2017
                            • 411
                            1577 KV - 4Y
                            Larry
                            What props are you running?
                            • TRUCKPULL
                              • 2969
                              ABC -1.7" and 1.8" Dia.
                              Larry
