I am thinking of up grading to a 50 amp esc . but it looks to have two water inlets and out lets. stock esc only has one . what is the proper way to adapt this? thanks
50 amp esc for shock wave
There looks to be 2 different sizes larger for water cooling .then the smaller one I should loop ? is this cange from 30 amp to 50 amp worth while. how will I notice a change ? thanks new to remote boatingComment
You won't see any change at all. It won't hurt anything, but if you aren't drawing enough amps to stress the 30 amp one you won't see any difference using a 50 amp one. It will probably run cooler though due to being designed for more current and having the cooling loop.
What do you actually want to accomplish by upgrading? I have a Shockwave 26 also, had it for several years. It's a reliable little boat if you don't try to overpower it.Comment
I'm assuming you have the green shockwave. If so I know that running a 5ooomah and 50c lipo will overheat that stock system! Aquacraft offers an 80amp for about $80 which will cure the over heating with that battery. I've done slight mods to my sons and mine to get a 7min run at about 35mph and still have everything cool. feel free if you have more questions.SW26 V3 Green 35mph , Swifter Hydro 26. Delta Force 35. cars ,3 Rustlers 45-76 Mph.Comment
I'm assuming you have the green shockwave. If so I know that running a 5ooomah and 50c lipo will overheat that stock system! Aquacraft offers an 80amp for about $80 which will cure the over heating with that battery. I've done slight mods to my sons and mine to get a 7min run at about 35mph and still have everything cool. feel free if you have more questions.Comment
On that boat there isn't a whole lot of tuning. As stated if your not overheating, which is hot battery, ESC or motor your the battery your using is good. The type or lipo #C is good. If and when you want to go faster is where money and tuning come in. Those are good boats, small problems may occur. Make sure you have foam in the front to save from drowning, and lube the shaft and you'll be fine!SW26 V3 Green 35mph , Swifter Hydro 26. Delta Force 35. cars ,3 Rustlers 45-76 Mph.Comment
There is but don't recall the # a stainless replacement for that. Unless your looking to increase the speed and spend lots of money on improvements USE the plastic! If you want to improve things a little, I can recommend Getting the 80amp aquacraft ESC, and then get a 5000mah 11.1 50c batteries. The prop shafts are weak, so next would have to remove shaft tube and replace with a 1/4'' brass tube. Then buy a $25 1.50 shaft from OSE. About 12'' and cut to size, then adjust the tube angle upward about 1-2 degrees. You'll also have to buy a collet/motor-cable connector to fit new shaft. THEN you can use an Octura 642 brass prop balanced and sharpened. this will get you about 35mph for around 7min. The stock collets are weak and so are the shafts, which are main complaints on this boat. So as you see if you up ONE THING leads to another! Again don't forget to put pool noodles, packing air bags or what ever to keep your boat. OH, also if waves are rough, OR you decide to up the speed you'll need to tape the hatch to keep it from breaking! So keep it stock and enjoy or jump in and learn the hard way of learning about boats. we will help you where we can.SW26 V3 Green 35mph , Swifter Hydro 26. Delta Force 35. cars ,3 Rustlers 45-76 Mph.Comment
There's no way I'd put that kind of money and effort into a Shockwave. Unless you also reinforce the hull with carbon fiber, it's still going to be too flexible to handle the waves at speed. And if you're going to do all of that, you might as well start with a fiberglass boat that's actually built to take abuse and last.
The tuning is fairly simple. You can blueprint the back part of the hull to make it perfectly flat. That will eliminate a lot of the bouncing. Before going into that though, basic tuning is adjusting the strut to get the right running angle and then fine tuning its behavior in the water with trim tabs.Comment
I do agree that there's boats for different needs and applications. I got started with this boat, and I'm trying to let this guy know that there's money that can be put to better things. But also note we've had a guy here that posted 68mph with this boat! But he is an experienced boater. I was happy learning all the things I did, even though I found out the hard way that I should have done it differently and could've had a better boat, like I do now. But I couldn't have built this one without learning on that one. We all have to start some where.SW26 V3 Green 35mph , Swifter Hydro 26. Delta Force 35. cars ,3 Rustlers 45-76 Mph.Comment
I am sorry but I misspoke on the 80 amp, it is 50 AMP. I would suggest this one that is in mine for the same price, Hobby Wing "SeaKing" 120 v3 Amp ESC that is sold here at OSE, it is also programable. My son has the 50Amp. Now, I also am running a 2030 6pole motor for more torque on mine. AquaCraft Brushless 6-Pole Marine Motor 36-56-2030 sold here as well. I will try to post pics of mine, if that will help.SW26 V3 Green 35mph , Swifter Hydro 26. Delta Force 35. cars ,3 Rustlers 45-76 Mph.Comment
