Very good info
  • Flying Scotsman
    Fast Electric Adict!
    • Jun 2007
    • 5190
    Very good info
    I received this PM from Anton and it would be a waste of excellent information, if I did not share it. Anton, if this upsets you send a message to the moderators to shut it down
    Hey, you'r welcome! I burned though 4 controllers learning this stuff, and I do know basic electronics well. But with brushless there are many things at play that do not make sense sometimes. Every time i call Castle, i beg for them to release a white paper or an article explaining in simple language how brushless works, how to set it up right, what to watch for and most important - what kills brushless controllers. I don't think Hydra is a bad controller, it's just there are so many things can go wrong, and people rely on old fashioned "if it ain't too hot to the touch, its running fine". This does not work with high power brushless. For starters, you NEED amp logger like eagle flight V3 for your boat. Make sure to keep it dry, because i killed one when it went underwater. I use conformal coating on everything now, and nothing died due to water yet. You have to know exactly how many amps that prop is pulling. Then you watch for voltage drop of your batteries. 25 - 30 C LiPo's have very low drop and are safe up to their maximum continuous rating. A123 batts have much higher drop and i killed one Hydra 120 HV due to that. Voltage drop was 8 - 10 volts for 47 volt system. That's 21% and that's a lot. My LiPo only sags down to 35 volts for 37 volt system. That's only 5% voltage drop.
    Keep wires short as possible, especially on battery side. Long wires have more resistance = more voltage drop = harder on caps = sooner failure. Sometimes, caps can't help at all, and FETs fail. Castle says no longer than 18" of wire for everything combined. Adding extra caps helps, but the spark when connecting power is harder, taking its toll on bullet connnectors.
    Check and clean your connectors often. Poor conducting connector will increase resistance and you know what will happen next... I use cotton swab dunked in Acetone on mines after every day of running. Keep them oil free.
    MAke sure your flex shaft does not vibrate too much. If you apply forward thrust force on vibrating shaft, it will dig into the walls of the stuffing tube or teflon liner, bringing your amps waay up. That has contributed to taking my ESC number 2 and 3 out.
    DO NOT use marine or stuff tube grease all over the flex shaft, without softening it up with some 3 in 1 light machine oil. It makes the shaft too hard to turn = much more unnecessary amps. I don't use that grease at all now, just a little on the stub shaft or the prop shaft between the brass bushing. I put that grease on first, then pour some light machine oil on it. I have teflon liner for the flex, and i soak it either with corrosion x or wd-40 or 3 in 1 oil. That's it. MAKE SURE to turn your shaft by hand, and check if its easy to spin. Some motors like on the supervee27 cannot be turned by hand. Both of my NEU motors turn just fine with slight cogging.
    Use 30C LiPo's. They are the best so far in my opinion. Use lipo's with lowest internal resistance you can find. Keep LiPo never hotter than 150 degrees Fahrenheit (not Celsius!) while in operation at any time. Use temp sensor that comes with V3 logger. Store LiPos in metal box, with wire connectors sealed off. Keep them stored at HALF CHARGE in cool place. They degrade much slower this way at about 2 % capacity loss per year. Fully charged in warm place is 20 % loss. After running the last run of the day, i charge them in storage mode, only to half the mAh rated. Then i put piece of silicone tubing on male bullet connector and store away in army surplus ammunition box with the lid closed, but not tight! You don't want an explosion if they burn.
    I am done for now, if you have other questions, ask.
    Anton Pustovar (AntronX)
  • AntronX
    • Jul 2008
    • 333
    LOL, i had a feeling you may post this. I am ok with that. Maybe others can contribute or point out my inaccuracies. I'll clarify some things of what i said:
    I was using two 7S2P packs in series, for total of 14S2P, 47.6V open cirucit, and 120A maximum continuous current rating at 30C. One pack was using brand new cells from a123racing.com and another pack was 6 months old, beat up and abused cells from dewalt power tool packs. Later i discovered dead cell pair in that 7S2P pack. I ran them like that in my big hydro project with 2 KB45XL motors and 2 Hydra 120 HVs. Each ESC pulled 60A, so the batts saw 120A. Even though, controllers were operating at half capacity, the voltage dropped down to 38 - 36 volts at full throttle from 47 volts no throttle. Ran fine one day, next day one Hydra came back warmer than another while making hissing sound. Opened it up and found 12 FETs charred, 6 per board, on both power boards on the same phase side.
    I've read about this on wikipedia about lithium-ion batteries. I believe Lithium-Polymer cannot be too much different from this. I did not confirm this personally about LiPos. I am only testing this right now. I about a year i should know if this helps for sure.
    Quote from Wikipedia:
    At a 100% charge level, a typical Li-ion laptop battery that is full most of the time at 25 °C or 77 °F will irreversibly lose approximately 20% capacity per year. However, a battery in a poorly ventilated laptop may be subject to a prolonged exposure to much higher temperatures, which will significantly shorten its life. Different storage temperatures produce different loss results: 6% loss at 0 °C (32 °F), 20% at 25 °C (77 °F), and 35% at 40 °C (104 °F). When stored at 40%–60% charge level, the capacity loss is reduced to 2%, 4%, 15% at 0, 25 and 40 degrees Celsius respectively.
    link: http://en.wikipedia.org/wiki/Li_ion#...ion_technology
