My TFL Zonda cronicals
One of four things:
1: broken water line that you cannot see. pull off inlet tube, plug outlet, blow through inlet tube with some water and watch were its leaking, been there done that (crack right at inlet of motor that I didn't see)
2: leaking from motor cooling can. Pull off inlet plug outlet, blow through it with water and watch were its leaking. May need replace O-ring (been there done that, was able to go to ace hardware for new ones)
3: Fittings on motor, thru hull fittings: same as above. extract them out and put some sealant on them and replace.
4: not enough grease in the flex shaft (yea water works it way up) most likely not as much as you say though. BUT: anyways, put shrink wrap on the strut and stuffing tube.
I'm just a newbe (4yrs) just some of the things I've come across so farComment
One of four things:
I'm not running the stock motors, drive shafts, cooling system, and only one stock 180 ESC that it came with. I pulled all the stock stuff and replaced it before I ran it for the first time. I grease the drive shafts after every run (main reason for getting the OSE one piece driveshafts). I don't have any water intrusion problems, it's actually the driest boat I have.Comment
I grease the OSE flex shafts after every run. I had some water coming in around the flex shaft tubing (clear silicone) where it came through the hull. I put it in a bath tub and saw water coming up through the flex tube. Ill check the rudder mount. I'll also try the things that JohnC suggested. Thanks for the suggestions.Comment
Ok, I give up. I guess I'll have to stick with the water. I sealed the rudder mount, and stingers. I've replace all silicone tubing. Checked Orings on motors. Checked and sealed all water oulets. If the boat is moving, not sure how water can come up and through the stingers and flex shaft? Put multiple rows of tape on the hatch. Even if I didn't put enough grease on the shafts, while the boat was moving...there should be no water coming through? I put the boat in the water and take off until the voltage drops enough and I come in...no sitting in the water for more than 10 seconds.Comment
If you're getting water up through the stuffing tubes you can try creating a seal (sort of) with some heat shrink over the end of the stuffing tube or a small piece of cooling hose. The trick with cooling hose is to get the right size so you're no creating drag on the flex cable. Shrink tube works good, but you need to have a decent amount of exposed stuffing tube for it to grab onto. Sometime mounts get in the way.Vac-U-Tug Jr (13mph)Comment
And I’m with Ryan on the silicone tube over the stuffing tube. 4mmID should work.Comment
