Flycolor 150 water inlet
  • Insanity Plea
    • May 2017
    • 562
    Anyone have an OSE part number or link to where I can buy this water fitting? Damaged in shipping and broke on repair...
    IMPBA 20583
  • martin
    • 2887
    That is quite a long fitting & might have trouble finding a replacement,if you cant find a replacement fitting i would solder it back together with a nice large fillet of solder or better still low temp brazing.
    • boatsrnew2me
      • Oct 2016
      • 476
      borrow one from a rudder you might have not in use??doesn't have to be same length .
      volantex vector pro ,proboat veles 29 , traxxas spartan, hobbyking/tfl pursuit ,ft009 with rescue rigging
      • RaceMechaniX
        • Sep 2007
        • 2821
        It's likely an M5x0.8 thread which is very close to a 10-32. I can't find the long one at McMaster, but I know they have some. You could call Rossi Sales (speedmaster) and order the long fittings.
        I only found a short one here:
        McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
        Tyler Garrard
        NAMBA 639/IMPBA 20525
        T-Hydro @ 142.94mph former WR
        • martin
          • 2887
          You could borrow a fitting from a rudder but make sure it has a 5mm thread, most medium size rudders have 4mm threads. Larger rudders like 130mm upwards have 5mm thread fittings, you could also use one of these from the OSE store part number tfl-521B03.
          • Johnc
            • Aug 2015
            • 199
            If you decide to try to solder/braze it, find a drill rod or some sort of metal shaft that fits inside, grease it up a bit and insert it before soldering/brazing. It will hold alignment and keep the inside from buggering up, the grease will keep solder from sticking to the metal shaft. Always try the infamous jb weld. lol
            • martin
              • 2887
              The fitting in the Flycolor 150 is deff 5mm as i have just removed a fitting to check.
              • Insanity Plea
                • May 2017
                • 562
                Thanks to all of ya for the advice & info! I definitely won’t be soldering or brazing, but I know I have extra rudder fittings and if nothing else, that OSE part number will work. I’ll post up the final solution when it’s done, thanks again guys
                IMPBA 20583
                • rol243
                  • Apr 2017
                  • 1038
                  You could remove the other end fitting and slide in a section of brass tube with abit of epoxy to hold the tube firm. drill out slightly larger to suit tube.
                    You mean like this:
                    • rol243
                      • Apr 2017
                      • 1038
                      No a full length of brass tube going right through esc, no threaded section.
                        I was replying to the op. In the pic I posted is an actual flycolor fitting. I had one burn up on me so I like to keep any parts off of them I can just for this purpose.
                        • Insanity Plea
                          • May 2017
                          • 562
                          Originally posted by kfxguy
                          You mean like this:
                          Exactly like that! Have one to spare?
                          IMPBA 20583
                            Yea I don’t need that one
                            • Norwest
                              • Mar 2014
                              • 165
                              rol243 has a excellent answer and solder both ends in threaded areas!!!!!!!!!!!! But why not use aluminum pipe from HS and use JB weld at threaded ends with pipe end sticking ou 3/4"! If I recall aluminum pipe cools better than brass!
