I need help with my Hitex Aggressor Srx Tx. I put NiMH batts in it but I can not charge it with my charger. I think there must be a diod blocking it but I can't find it. Can someone post a pic of where it is and how to do it ?? PLEASE
HELP with Hitex Aggressor Srx Tx
My Schulze chargers will not charge HiTec radios because of this diode. They like to talk to the batteries and this diode prevents two-way communication between the charger and the battery. I found a small circuit board in the battery compartment, but I simply opted to use a wall-wart or a cheaper charger to do my charging in-the-field.A nation of sheep breeds a government of wolves -
I have the same problem with my Astro 110D. All I do is plug the charger into a "regular" NiMH pack for a few seconds until it recognizes the pack, the unplug the charger and re-plug it into the transmitter. This works great, but I don't know how well the charger will work to shut off the charge when the transmitter pack is full. Mine usually shuts off and I have never overheated the transmitter pack, but then I usually charge at pretty low rates.
