Turnigy receiver relay swicth
  • grsboats
    • Jul 2012
    • 975
    I installed a micro water pump(brushless) on my twin rigger just to improve the cooling of my esc's/motors activated by a nano servo and micro swicth and the results were impressing.Then I knew that HKing sells receiver relays swiches controlled via radio and got two of them with the purpuse to get a cleaner set up but have tried for hours to get them work with no sucess...I guess there is a miscomunication with my Futaba Faast radio...anyway if someone had sucess with these small devices let me know. Thanks in advance
    link to the product:https://hobbyking.com/en_us/turnigy-...ay-switch.html
    Gill
    GO FAST AND TURN RIGHT !
    www.grsboats.com.br
  • RaceMechaniX
    • Sep 2007
    • 2821
    Gil have you tried switching the servo response speed? Try using a non-digital or non-HRS mode. The relay switch may function like an older analog servo.
    Do you have a servo tester?
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • TRUCKPULL
      • 2969
      Gill
      This is one of the first reviews that I read.
      (( Customer Rated Richard
      As stated in review the relay circuit is very voltage sensitive and will not work at 5 volts or more.
      Placed a diode in the positive servo lead to drop voltage to 4.6 volts and everything works fine.
      Good unit and since the unit has a single throw double pole relay you can turn on/off two different circuits. ))
      Larry
      • grsboats
        • Jul 2012
        • 975
        Tyler I've already tried this and it doesn't work, well I will get a try to what Larry posted.
        Thanks guys
        Gill
        www.grsboats.com.br
        • dmitry100
          • Mar 2015
          • 1264
          why would you need a switch? wouldn't it make more sense to just keep it on?
          • grsboats
            • Jul 2012
            • 975
            Well a remote swicth is something nice but since it doesn't work I first installed a nano servo to activate a microswicth but I got rid of the servo and now i only have the swicth. As the pump is brushless and its power consume is very low a 1,8A 3S lipo is enough for my three minute ride. Gill
            www.grsboats.com.br
            • NativePaul
              Greased Weasel
              • 2760
              Like leadteflon bearings in struts, lots of pumps will burn up real fast if run dry. If you don't run a safety loop so the boat is only live just before you chuck it in, you are likely ruining the pump with it running dry every time you tape up and walk to the water.
              If you race or do SAWs, as I believe GRSboats does, it can be several minutes from plugging in to launching, and the pump seals may be knackered before it ever got wet.
              • grsboats
                • Jul 2012
                • 975
                My twin rigger is a heat boat that I use to play(not compete) with other twin gas boats during test sessions as our rules do not allow Fe riggers.Anyway the pump is activated via a waterproof micro swicth mounted on the rear lid just as the boat hit water and its working good for almost a year with no issues.
                Gill
                www.grsboats.com.br
                • dmitry100
                  • Mar 2015
                  • 1264
                  What kind of brushless pump are you using?
                  Does it use a noticeable amount more of battery compared to brushed? I think I noticed a tiny 6v diaphragm pump use a good bit of battery even on dry. Like 40-50% of a 2s 1100mah LiFE after about 10-15 mins.
                  • grsboats
                    • Jul 2012
                    • 975
                    Dmitry the one I use is very economical on the battery compared with the brushed I've tried. Here is the link to ebay:
                    Gill
                    www.grsboats.com.br
                    • Mike W
                      • May 2018
                      • 348
                      Do you run that one on 6V?
                      Otto RC Marine
                      • grsboats
                        • Jul 2012
                        • 975
                        I run it on 12v( 3S 1,8 A transmitter battery), 6v isn't enough for best performance. I'm out of town but as soon at home will post some pics. Gill
                        www.grsboats.com.br
                        • grsboats
                          • Jul 2012
                          • 975
                          here pics of my twin rigger set up using a micro waterpump.The microservo to activate it is back cause I had problems with the "waterproof" swicth positioned on the rear lid. Gill
                          www.grsboats.com.br
                          • Mike W
                            • May 2018
                            • 348
                            Nice boat! One pump is enough for a twin motors and ESCs?? What pickup?
                            Otto RC Marine
                            • grsboats
                              • Jul 2012
                              • 975
                              Thanks Mike yes this one working on 12v is enough (240l/h).The pick ups positioned behind the props are in charge to feed the pump (inline) .
                              link : https://www.youtube.com/watch?v=NX9d-SZlXik
                              Gill
                              www.grsboats.com.br
