Soldering-
  • Norwest
    • Mar 2014
    • 165
    Soldering-
    How do you keep the soldering iron clean. I use 60/40 solder with a wet sponge for cleaning but to no luck. The iron has no heat control which might be the problem. I have a lot of soldering to do today and would like not to have the hassle, thanks for suggestions!
  • Norwest
    • Mar 2014
    • 165
    I just went to a site and showed me the way to do it. Thanks anyway!
    • NativePaul
      Greased Weasel
      • 2761
      I use a moist sponge too, and it works well for me. I have seen pros use what looks like a pot of brass swarf. I am curious as to what the site said, while a sponge works well for me, I am no pro and maybe something else would work better, since I started using lead free solder my tips erode much faster, and maybe the heat cycling of constantly cooling it down on the sponbge and reheating it doesn't help.
      • tlandauer
        • 5666
        I use moist sponge too, never a problem. After you wipe the tip, the tin should be shinny and tightly "coating the tip area", if there is a blob, the only way is to flick it off, a quick wrist movement will do. Just be sure you have a place to flick because the solder balls up to many piece.
        As said above, the tip has a definite service life span and it can get eroded and that's when things go south.
        A good working tip should always have a layer of tin on the tip that looks shinny and conforming to the the shape of the tip.
        • grsboats
          • Jul 2012
          • 975
          I tried both ways and the brass swarf is my second choice as it does no clean and keep the tip shiny as the moist sponge.Gill
          GO FAST AND TURN RIGHT !
          www.grsboats.com.br
          • Norwest
            • Mar 2014
            • 165
            Clean iron and tin area and use a wet sponge.
            • Norwest
              • Mar 2014
              • 165
              soldering
              Tried to type more to answer posters but I was proof reading as I go and it doesn't like slow typers!
              • Norwest
                • Mar 2014
                • 165
                Best to wrap solder around cold iron after cleaning and plug iron in and all will be great.
                • Norwest
                  • Mar 2014
                  • 165
                  NativePaul- Try leaded solder which seems to not blacken iron as much. Best I can help you. I read you guys post a lot. I'm kind of a young loner at 81 1/2. Been at this hobby since 1991.
                  • tlandauer
                    • 5666
                    Also prolonged heating when you have idle time will oxidize the tip, I turn off the rig and let it cool off a bit and wipe with wet sponge again, it will retain the shine, good for next session.....
                    • jim82
                      • Jan 2013
                      • 1358
                      I just recently got some Hakko FS-100 tip cleaning paste that is supposed to work really well. I can't comment on it myself I haven't had to use any just yet
                      • lt130th
                        • Apr 2014
                        • 858
                        Seems like the original posted question has been addressed, so now I'll ask - why are you guys still using soldering irons? Are you soldering small electronics (cap banks & such)? 99% of my soldering is bullet connectors, and for that I use a pencil torch. It will do all bullets on an ESC in 60 seconds.
                        • rol243
                          • Apr 2017
                          • 1038
                          you can,t use a torch on all soldering jobs, thats why we still use the good old soldering iron.
                          • Prodrvr
                            • Jul 2015
                            • 701
                            I use that brass wool thing to clean as I solder. After I'm done soldering, I clean it in the brass wool then apply some solder to the iron and shut it off. I use lead-free 4% silver solder.
                            • lt130th
                              • Apr 2014
                              • 858
                              I also read, in another thread, that the friction/flow of gas over a bullet connector can create a static charge. This could be potentially bad for an ESC. I didn't even know about that. I've used a torch on many ESC's & LiPo's, though, and not yet encountered an issue...maybe I've only been lucky.
