Proboat blackjack 29. 4s.. 50mph
  • jake414
    • Mar 2018
    • 64
    Just picked up a proboat blackjack 29. I currently have 2 turnigy heavy duty 4s lipos.
    I'm going to cut the plug off the esc and put my xt 90 on it. Then I have a harness for 2 4s in parallel. Will this work?
    Also how do I make it run 45 or 50mph. What prop?
    Sent from my SM-G955U using Tapatalk
  • Speed3
    • Mar 2017
    • 371
    Try an octura m545. Make sure all connectors are properly soldered. I would use 2 2s packs between 5000mah and 6000 mah 50c or greater. If the packs are new never been charged. Charge them to 4.15volts per cell. Do not go 4.2 volts but 4.15 volts per cell.
    This should get you 45 plus on 4s with the stock motor.
    • trigger
      • Sep 2013
      • 853
      What MAH are the packs? and what class do you intend to run or are you just playing "sport boating"
      • jake414
        • Mar 2018
        • 64
        They are turnigy 5000mah 60-120c packs. 4s.
        Mostly pleasure boating.
        I was reading the octura x642??
        • trigger
          • Sep 2013
          • 853
          I personally wouldn't start with much more than a x442. tune it in, make sure the heat is in control. Then bump up in sizes and tune as you go. Bring it out to an admirals race... http://www.indyadmirals.org/. there will be plenty of folks to talk to and you'll see folks running first hand.
          • jake414
            • Mar 2018
            • 64
            I'm not really trying to buy a bunch of 50 dollar props.
            I can handle decent speed I had a revolt 30 that did 45 50.
            It's not my first rc or rc boat
            • rol243
              • Apr 2017
              • 1038
              If you want more speed you need to modify a stock prop such as an Octura x series. at around $15 a prop from O.S.E . you can,t go wrong.
              • jake414
                • Mar 2018
                • 64
                Why? Theres 3 different people saying a prop that will make my boat faster..
                • MADRCER
                  • Feb 2017
                  • 751
                  Becareful who you get your info from cause it can get expensive. That boat with tolerable temps won't do more than 42-45mph at best on 4s with the stock 3910 motor without burning something up. I would change the motor out to the new 3831. Both my Geico 29 v3 and my Veles 29 will do 55mph on 4s with the new updated Dynamite 3831 replacement motor (while running a dasboata abc prop) all day long with tolerable temps. Also, I wouldn't cut the series plug off either. I would get me an plug to "short out" the extra series plug. Because later down the road you will realize that the (2) 4s packs are too heavy for this boat and will want to run (2)- 2s packs. Good luck with it.
                  • jake414
                    • Mar 2018
                    • 64
                    I read multiple posts from a thread back when the boat came out on what prop abd they said the one mentioned.
                    Can you link me the motor? My boat is the v3 with the 2000kv motor if that matters.
                    Already cut the plug had to put my xt90 on it. So now I just plug in my series harness or my parallel.
                    • jake414
                      • Mar 2018
                      • 64
                      I already cut the plug.. I soldered on one xt90. So now I use my parallel harness or buy a series harness
                      I'm looking to do mostly recreational running.
                      Can you link me to that motor? When I type in those numbers it brings up a 2000kv motor that mine has.. it's a v3 if that matters?
                      • MADRCER
                        • Feb 2017
                        • 751
                        If you just purchased the boat new it is a possibility it already has this motor.
                        https://www.offshoreelectrics.com/pr...od=hh-dynm3831
                        • jake414
                          • Mar 2018
                          • 64
                          It doesnt it has the 3910.
                          I kind of just want to run this In the mean time.. what do you suggest for a prop then.
                          • MADRCER
                            • Feb 2017
                            • 751
                            A Pro prepped X642 will be low to mid 40's on 2 x 2s lipos. Not sure on the 2 x 4s packs you will be running. The boat will be overworking itself trying to compensate for the added weight. You might have to run (1) 4s pack on the left side.
                            • jake414
                              • Mar 2018
                              • 64
                              Wont that mess with how it runs?
