Need Help... TP Power 40 series motor diameter
  • longballlumber
    • 3132
    What are the chances that someone can measure the OD of a TP motor 40 series can? They state the OD is 39.5mm. I want to see how close the physical measurement is on a couple of motors.
    Thanks
    Mike
  • RaceMechaniX
    • Sep 2007
    • 2833
    Mike I can measure some when I get home tonight.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • zooma
      Local club FE racer
      • May 2014
      • 652
      Thanks
      Mike
      Ah Ha. That would explain why the 40mm tail ring is a little loose on a TP 4074 can. Good question Mike.
      Ron - The Villages, FL
      • TRUCKPULL
        • 2975
        Mike
        On my TP 4050's
        Can - 40.08mm or 1.578"
        It is bigger then the NEU 1515 because a 1515 water cooler from Ham will not fit.
        Larry
        • HRC
          • Jan 2008
          • 328
          Mike,
          It drives me crazy trying to keep up with the TP can sizes for making jackets and mounts. The V 2 motors are 39.5 mm and TP V1 are like Larry said just a tad over 40 mm. One needs to be sure what motor you have to get the proper jacket. Hope that helps.
          Dave
          • longballlumber
            • 3132
            Thanks guys,
            This was helpful! I appreciate the replies.
            • longballlumber
              • 3132
              For what it’s worth, I have one of each;
              V2 - 39.5
              V1 - 39.99
              • fweasel
                master of some
                • Jul 2016
                • 4291
                And to keep it clear as mud, V2 are the older motors, and V1 are the newer models.
                Vac-U-Tug Jr (13mph)
