Finding CG
  • awfireman
    • Jan 2013
    • 90
    Finding CG
    What is the best procedure to find my hulls COG? What is the ideal COG on a mono....between 28-30%? What should I balance the hull on to find my current and future COG? . My hull is 32" from tip to transom (without rudder), 35.25" with rudder included. I am assuming you use the hull length without the rudder? Thanks again guys. A lot of questions lately and I appreciate all the help!
    -Fireman
  • properchopper
    • 6968
    There is not necessarily a "perfect" % for CG - depends on your running preferences. Smooth water zoom-zoom runs will benefit from an "aired out" running attitude with minimum hull in the H2O. Racewater requires somewhat more forward CG to keep the bounce-landing under control. Besides CG there's other tuning factors that affect running attitude : prop depth, propshaft angle, prop lift, rudder angle, tab setting and even to some extent hull aerodynamics. For monos I prefer to start tuning at roughly 28-29 % measured bow to transom (not including hardware) and play with the other variables I just mentioned.
    I use one of these (4-pack available at local el-cheapo furniture mart for $29.95 and come with free nightstand)
    And then
    Enjoy
    • fweasel
      master of some
      • Jul 2016
      • 4286
      Good for monos, cats, and dogs!
      Vac-U-Tug Jr (13mph)
      • awfireman
        • Jan 2013
        • 90
        Thanks for the help and info chopper! Nice "tool" to find COG...dont need the nightstand though!
        • 785boats
          Wet Track Racing
          • Nov 2008
          • 3169
          I wish I could afford one of those Super Hi-Tech CG-O-METERS
          • CraigP
            • May 2017
            • 1464
            Keep in mind that the side-to-side balance is very important on monos. I had to weight one side to offset the rudder gear and servo. A properly trimmed mono will ride pretty high in the water on acceleration going straight and needs good side-to-side balance to keep off the trim tabs...
