SV27 Strut and Rudder on SH?
  • boater76
    • 505
    I was thinking of using the sv27 strut and rudder on my 40" SH knock off. I am going to use 700sc and Jeti 600 and 14 cells. Anyone think this would be a good application or would I need something different. Thanks.
    Ken
  • ReddyWatts
    • 1711
    It should work ok. Probably run in the 20's.
    ReddyWatts fleet photo
    • boater76
      • 505
      When a rudder is offset instead of inline does the boat turn differently? I have never dealt with offset rudders.
      Ken
      • saleens7
        • 1108
        well, if its offset to the right, it turns right just a tad better, but you also get more speed because the prop wash isnt blocked and it also somewhat counters the effect of prop walk...
        • boater76
          • 505
          Ohhh I get it. I should have thought about that.
          Ken
          • Steven Vaccaro
            • 8721
            That's a really large boat for that rudder. Make sure when you mount it you can get atleast 1" of rudder below the prop centerline.
            • boater76
              • 505
              What's the minimum you think I should go with?
              Ken
              • Steven Vaccaro
                • 8721
                It really depends on the size of the transom and where it would be mounted.
                • SJFE
                  • 4735
                  The transom on that boats very tall. You will have to mount that rudder low in order for it to get a good bite.
