Self-righting hull deck inlet holes
  • Old School
    • Aug 2017
    • 686
    My two just completed self righting hulls have three large water inlet holes in the deck. While this does speed up filling of the flood chamber, are they really essential? Some drill holes in the deck while others drill holes in the side of the hull to assist speedy ingress of water. Obviously the more holes the quicker the chamber fills and flips the boat. This feature may be important for racing applications, however, I do not forsee such activity.
    I know that several holes are needed on the underside of the hull at the most forward point of the chamber to allow air to escape. Personally, I feel that when the boat flips upside down then water will enter the large exit hole in the transom and air escape through the forward holes in the underside of the hull. The process may be a few seconds slower than if the deck was festooned with inlet holes, but for sporting purposes are all those additional deck holes really necessary?
    Many converted boats have a lot of deck inlet holes but these boats seem to be primarily European boats used for racing where less time spent upside down is a racing advantage.
  • NativePaul
    Greased Weasel
    • 2760
    No they are not really needed, as long as long as the transom hole is below water level and there are air outlets at the high points it will work fine, as you say deck holes just speed up the ingress of the water making the roll quicker.
    If you are not racing and don't care about the speed of self righting there is no need to have them, but then again there is no real disadvantage to having them.
    • Old School
      • Aug 2017
      • 686
      Many thanks Paul.
