With the completion of two Arowana 32 inch self-righting hulls which did require quite a lot of alteration to make usable, I thought to myself that making a self-righting Pursuit hull should present no additional challenges. The Arowana and the Pursuit share the same basic hull with each having a different deck and hatch moulding. Additionally, the Arowana has a slightly canted transom requiring either a very thin wedge under the rudder mounting face to keep the forward edge vertical or in my case I slightly modified the hole for the breakaway bolt in the rudder blade to enable the rudder to sit vertically.
Hobbyking had a sale on the bare Pursuit hull with free shipping from my local Australian wharehouse and the hull was delivered the next day after purchase. The Australian Hobbyking staff are brilliant when it comes to preparing goods for shipping and getting them picked up by the courier. All up cost was less than $120.00 Aud ($92.00 usd).
Yesterday I stumbled upon an old OSE thread from mid-2015 in which TFL announced it was after expressions of interest in a factory self-righting Pursuit hull. I understand the pros and cons presented by both sides and apparently the degree of negativity to the proposed project killed it off. Not having an inclination to go racing, I did side with the sporting crowd who understood the practicality of the design. I also understand the negativity from the American racing fraternity who believed it gave the racer an unfair advantage, plus the danger presented should a boat flip, self-right itself and then have to travel against the flow of racing to turn itself around.
I have purchased a quick change 40 mm motor mount from OSE plus a stuffing tube mount. I liked the idea of the quick change mount as I can place the inner flood chamber wall right up to the left side rail of the mount. With my Arowana build I had to space the wall out a little to allow access to the front motor mount ring retaining bolt. This did limit the water capacity of the flood chamber, however, in hindsight the modified Arowana hull will flip itself back immediately it is flipped over so obviously there is more than enough port side bias to unsettle the boat when flipped over.
While awaiting the mount to arrive I can proceed with a carbon fibre inlay in the hull. I need to install the motor mount rails before commencing the flood chamber install as I need to see how close to the centre of the boat I can extend the inner wall. Also part of the design will be to provide clearance to enable at least one 6s battery to be fitted to the rear port side wall of the chamber. On my Arowana builds there are rails the full length of the hatch opening and these restrict the available height under the hatch restricting me to two 3300 mah 3s batteries in series. Hopefully, I will be able to fit two 6s batteries in parallel and get some usable runtime.
I already have a spare Pursuit bare hull plus fittings from a previous Hobbyking sale to make a non-self righting hull. Having the quick change motor mount in the self-righting hull will enable easy transfer of the motor and ESC between each boat until I source another motor/ESC combination.
Hopefully I learned enough from the two Arowana builds to avoid some of the traps in making the hull water tight on the Pursuit.
