How to clean out smoke smell?
  • zooma
    Local club FE racer
    • May 2014
    • 650
    So it finally happened that I smoked an ESC. The inside of the hull is covered in smelly soot. What is the most effective cleaner or solvent. Right now, I don't even want to leave it in the garage. Yuk.
    Ron - The Villages, FL
  • Doug Smock
    Moderator
    • 5272
    https://forums.offshoreelectrics.com...urnt+ESC+smell
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • Bp9145
      • Jan 2016
      • 1466
      I've used alcohol before, different types of soap, even nail polish remover. I tried all this on one hull and it took most of the smell away but it still lingered. then I tried just alcohol as it seem it was better than soap and then I put some car wax and some car cleaner stuff to see if that would do something. I left it on overnight and then applied alcohol the next morning. Again, the smell was there but this time not as strong. I can actually say it was subtle but was there. I did this several times over a few weeks and it finally went away.
      • fweasel
        master of some
        • Jul 2016
        • 4282
        I wonder once the initial clean-up and treatment is done if something like febreeze would knock out the remainder.
        Vac-U-Tug Jr (13mph)
        • Bp9145
          • Jan 2016
          • 1466
          I actually tried that and yes the smell seems to be gone but it does comeback. However, I only applied it like twice. Perhaps multiple applications might have better results but I know Febreeze doesn't last long as I use it around the house. Ryan, maybe we should push some of our cheaper escs over their limits to see what else could work. LOL
          • NativePaul
            Greased Weasel
            • 2760
            Brake cleaner.
            • zooma
              Local club FE racer
              • May 2014
              • 650
              Brake cleaner.
              I am going to try that next, thanks. On day one, I have made a lot of progress. Scrubbed twice with lemon scent Simple Green and ScotchBtite pad.. After dry, scoured with Scrubbing Bubbles cream (with abrasive), rinsed and dried. Wiped down twice with denatured alcohol, still left a film. Wiped worst spots with straight acetone, which worked on some of the residue. So, I'm thinking that the brake cleaner will finish the job. It's pretty good so far, but I'll report back after the brake cleaner.
              • boatsrnew2me
                • Oct 2016
                • 476
                when not using it throw a few dryer sheets in it and put the lid on .
                volantex vector pro ,proboat veles 29 , traxxas spartan, hobbyking/tfl pursuit ,ft009 with rescue rigging
                • MADRCER
                  • Feb 2017
                  • 751
                  Carb cleaner for the initial clean up. Then I put a couple of dryer sheets along with some peppermint oil on cotton balls in the boat and left the hatch on when it wasn't in use and that done the trick for me when a 60 amp AQ ESC decided it was time to explode....
                  • NativePaul
                    Greased Weasel
                    • 2760
                    Oops, now you have abraded it, I doubt it can be wiped off the surface with any chemical, as it will be inside all of those abrasions. There was a guy on here that resorted to giving his hull another coat of epoxy on the inside to lock in the stink.
                    • jevmax
                      Legend
                      • Aug 2007
                      • 368
                      A liberal application of denatured alcohol works the best. Try it.
                      • revoltrunner
                        • May 2014
                        • 646
                        Awesome cleaner removes the smell and soot very well.
                        it is also great stuff for other cleaning jobs.
                        you can get it at most dollar stores.
                        • T.S.Davis
                          • 6221
                          Great idea. Awesome cleaner is good stuff. Never thought about using it for that.
                          Citrus hand cleaner eats the smell but it's a pain.
                          Noisy person
                          • revoltrunner
                            • May 2014
                            • 646
                            I used it to clean up this hull I bought.
                            https://forums.offshoreelectrics.com...highlight=MG29
                            • zooma
                              Local club FE racer
                              • May 2014
                              • 650
                              Looks like you painted the inside after the cleanup.
