Jacking plate
  • Mph621
    • Jan 2013
    • 150
    Jacking plate
    Does anyone know of a outboard motor jacking plate for rc boats? If not I am thinking of milling a few out to try on a project. Is there any interest? I was hoping a few were already made commercially but I can’t find any
  • MadProps
    • Mar 2017
    • 236
    prather makes one for gas but they are too large for most the FE outboards
    • Mph621
      • Jan 2013
      • 150
      Thank you I will check it out
      • Mph621
        • Jan 2013
        • 150
        Could you happen to provide a link I can’t find it
        • Doug Smock
          Moderator
          • 5272
          There is a gentleman (Captain Vic) on International Waters that used to sell them, not sure of his current status.
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • MadProps
            • Mar 2017
            • 236
            sorry cant remember where I bought the prather jackplate but here is a knockoff sold as "Prather Style JackPlate"
            • MadProps
              • Mar 2017
              • 236
              here is are some nice setback mounting brackets OSE sells, the mount holes are slotted for some adjustment on the transom, but it would be much nicer if it had an adjustable jackplate & take it a step farther than I modified my OSE setback mounts "add built in tilt/trim" while your on the engineering project..... I have a design in mind Im just not capable of producing it. if your interested
              maybe the guys building F1 hydros would be interested in something like this, I know I would like a one piece setback with adjustable jackplate and trim all in one unit for my next build
              I made an adjustable jackplate to mount on these OSE setback brackets (made this video for another post)
              • JestDanny
                • Jan 2017
                • 174
                What type of hull are you going to mount the jack plate an outboard too? On my OPC tunnel boats I like the Prather mounts available thru K&B mfg. in both 3.5cc an 7.5cc sizes 30$ or so. I also use K&B lowers on my tunnels, so they were made for each other, not sure what other lower O/B unit would fit the Prather mount? Du-Bro also makes adjustable mounts for O/B's also for K&B an O/S lowers not sure it is compatible with any other O/B lowers? I guess it all depends on what O/B and what hull you are using it on, commercial ones may not be available, you may have no choice but to fab up your own design.
                PROBOAT BlackJack 24", ShockWave 26"
                MRP U-31, 3 tunnels VS1, MRP Bud Light, Dumas HS Sprint
                • Mph621
                  • Jan 2013
                  • 150
                  I am going to run two ose mini o/b on a nitro converted to electric blackjack 26
                  • JestDanny
                    • Jan 2017
                    • 174
                    I've seen a few of those BJ26's on flee-bay, thought they would make a cool O/B conversion. What's the transom height on that hull, spoonson bottom to top transom? Larger 3.5cc size O/B's need 3" transom height, those mini's and the H2O style only need 2" transom height. Probably going to need a one inch spacer / mount for front of O/B motor to hull clearance.
                    • Doby
                      KANADA RULES!
                      • 7280
                      Those were a very tippy hull..not sure adding outboards would be a good idea.
                      Grand River Marine Modellers
                      • Mph621
                        • Jan 2013
                        • 150
                        I had them on it already ran pretty well just need to be able to adjust the depth
