building this kit to run my leopard 4082 1600kv on 6s with a seaking 180. battery is a 5000mah 70c revo 420. video is of my abs rigger or 5 years ago. in everyones opinion will this fe33 run as well as this boat in the video, or should I consider a TP on 4s with higher mah. to make the 6s 5000 mah battery fit, I had to remove battery mount and redo. I heard someone mention that a TP 3650 on 4s might run longer than a 4082 on 6s. if i went to 3650 on 4s with high mah, could i use the 180 esc? https://www.youtube.com/watch?v=MW9nbYBlsEI
zipkits fe 33
Two things influence run time - amp draw and pack capacity. Motor efficiency has a minor influence, but for a given speed a 6S setup will pull only 2/3rds the amps of the 4S setup, and you may not the large format 4082 motor, a 3674, 3685 etc. would probably work. So with the same battery capacity the 6S setup will run much longer...except that the packs will weigh 50% more and take up more space. So for the same weight you can use higher capacity 4S packs and get the same run time as the 6S setup.
If I didn’t have to worry about racing rules, I’d run the 6S setup. It’s easier on the components and for the runtime is about the same cost. Racing rules depend on the class.
6s Jae Leo 4082 1550kv 120amp dynamite esc ABC H7 5000mha 50c cheap Lipo. I heat raced it and it never harmed the lipos.Gold SpiloComment
zipkits fe33
.Comment
https://m.youtube.com/watch?v=R-ZIasTsUCw
6s Jae Leo 4082 1550kv 120amp dynamite esc ABC H7 5000mha 50c cheap Lipo. I heat raced it and it never harmed the lipos.Comment
zipkits fe33
that was 4s, right? what batteries were you using? how does the keps p compare to the jae33? what prop did you use on the 6s leopard? might build another jae 33 for a tp3650. sorry for all the questions, lol.Comment
Yes the keps is 4s P rigger. I used cheap electron pro 5200 50c on both the Jae and keps. The keps is slower to me than a Jae. I used a ABC H7 on the Jae.Gold SpiloComment
If you want a good 6s rigger I would suggest the ML boatworks 380 rigger kit. It has plenty of room for 2 6s 5000 or even 6000 mah packs. I run a TP 4070 1520 with an ABC 2215 prop and the boat drives like a cadillac. It's close to 80 mph and is so fun to drive. The Jae33 is more of a 4s boat and space will be tight. The ML 380 rigger is 4 1/4" wide and 38" long. It's a big boat with lots of room for everything. One of these days I will get a video of it running. If you go this route I will be glad to help you and show you all the parts I used.
MarkLast edited by MarkF; 02-14-2018, 07:33 PM.Comment
