Prop height....?
  • creekrunner
    • Dec 2017
    • 51
    Prop height....?
    What's the rule of thumb for setting outboard (EP650_) prop shaft height in reference to boat bottom? re: flat bottom "drag
    boat"
    thanks
  • MadProps
    • Mar 2017
    • 236
    same with this flat bottom, start with prop shaft level or an 1/4 inch below bottom of hull and start jacking it up untill you find the sweet spot
    • creekrunner
      • Dec 2017
      • 51
      .....I believe you're talking about full size race boat applications.....I use to run my "quickies" on a BSR with prop shaft center 1" below boat bottom.
      I was thinking starting at 1/4" below on my 27" scale flat bottom Daddle .....just wondering if I'm in the ballpark ?
      • MadProps
        • Mar 2017
        • 236
        sorry that was a typo start at a 1/4 inch below and work your way up, its where I have my EP650 mounted I was going to start with level but was worried all that work and if it wasnt deep enough it would be on me ( the quickie above is 1/4 inch below)
