Pacer Z-poxy finishing resin ?
  • Andris Golts
    • Jan 2011
    • 504
    Hi all. Does anyone know if this finishing resin is 100% waterproof ? I want to test my wooden micro mono in the pool before i paint it ? Regards Andris Golts.
  • rol243
    • Apr 2017
    • 1038
    the other z-epoxy resins are waterproof so i would expect this 2 part finishing resin by z-pozy is waterproof as well.
      • 8012
      The manufacturer says: “great for sealing model boat hulls, inside and out.”
      • NativePaul
        Greased Weasel
        • 2760
        All epoxies are waterproof if applied well, open grain woods will absorb quite a lot though, so it is best to apply 2 coats allowing the first to dry before the second. The first coat should have as much wiped off the surface as possible, it is just to get into the wood and stop it absorbing the second coat, which seals it up.
        • Andris Golts
          • Jan 2011
          • 504
          Thanks for the great information. Regards Andris Golts
          • Shooter
            Team Mojo
            • Jun 2009
            • 2558
            Paul,
            Do you sand between seal coats? I am still trying to perfect the sealing method. I end up relying on epoxy paint to truly seal the boat. Multiple primer coats and then finishing the top coat with 800, 1000, 1500, 2000, and 3M finesse-it.
            • rol243
              • Apr 2017
              • 1038
              i find an old stanley knife blade works very well of scraping back the epoxy between coats, seems to work better than sand paper and leaves a very smooth finish.
              • ray schrauwen
                • 9471
                That's an interesting method. I learned on here to try and apply it with an old white 100% cotton shirt and I like that. seemed to go on nice and light not requiring much after.
                Nortavlag Bulc
